Potd - Project Of The Day- What Did You Do In Your Shop Today?
Status
Not open for further replies.
kvt
Oct 21, 2014
2,083
Hey, Those look nice. Are you going to do anything to them to help protect them. Bluing, Anodiz, or something.
jrstech
Active Member
Feb 8, 2014
106
I hadn't planned on it. They are somewhat disposable. Just made from cold rolled steel. I dismantled my hot salts bluing station to make room in the garage for the new mill. I guess I could heat them and oil dip quench to give them some colour.
ogberi
Oct 20, 2014
494
Today, no air conditioning. Yeah. Not pleasant at all. Tracking down a new controller board, if I can't get one by Tuesday morning @ the latest, i'm buying a window unit to get us through until the new board can be obtained. No way in hell am I shelling out several grand to replace an ageing but still healthy chiller/heat pump and air handler "just because it's R-22."
zmotorsports
Mar 12, 2014
1,494
I finally made time Saturday to finish up some windshield/handlebar mounts for a buddies Harley. I made the bore and squared up some stock a couple weeks ago. Now I just had to turn the radius and complete them.
Started by making a mandrel to mount the blocks on my rotary table.
Boring to fit over the morse taper/mandrel.
Test fit before removing from lathe.
Now test fit into the rotary table.
Set up on the rotary table.
Dialing in on center. That little modified NOGA test indicator holder sure comes in handy.
Plunging away around the radius.
I made a climb milling finishing cut.
I then flattened off the ends where the fastener will be.
One down, one to go.
Setting up the second one on the rotary table.
Ready for the next step of removing the center portion.
Center portion removed and deburred.
I didn't have any .625" stainless steel rod so I had to improvise and use some stainless steel bolts.
Getting closer.
Set up in the collet block to drill the .380" hole through the head.
Completed and ready to be picked up by the owner.
All in all a pretty straightforward and fun little job.
Mike.
Round in circles
Jul 9, 2014
606
You can never have enough space in your man cupboard can you ? Be it a small cubbyhole under the stairway o a 600 foot x 700 15 ton foot crane gantry three phase set up ,you can always do better .......... Can't you ?
So to this end I decided to sort out some of the accumulated junk that's too valuable to throw out to the recyclers , but where to put it ?
I decided to make some sort of shelving set up's for all the legged equipments in the small garage the shelves being put inside the legs and using the legs as part of the frame work . This is the old back lathe looking from the back of it ...suitably modified .
IMG_6012_zps4pyhpcqg.jpg.
It worked so well , so it was not long before I was all set up again to start doing the " Priority " POTD's which was to sort out the cheap set of calipers and the divider I mentioned a few weeks ago that has British standard Chinese Korean Sub Saharan thread forms of the adjusting nuts & it's screw thread adjuster in such high quality steel that they stripped the threads off after the first few times they were used . At the time I didn't realise that the adjuster has slipped a thread or two ..no wonder things wouldn't fit on the things I'd made using them for setting & checking measurements .
This is the first caliper .. I ground the adjuster bar in two after carefully taping the legs together to stop them flying apart . As I carefully undid the two legs ( Yes you guessed it ) "Ping " the fulcrum axle flew out over my right shoulder ..three hours late I found it laying in a fold of metal on the garage door.
It took a while to file the old burred & lase fused over end of the adjuster thread off & carefully centre punch it for drilling out . I guess it was the only part of the threaded bar that had decent steel in it .
Drilling it out with a 1 mm drill and then a 2 mm drill was precarious to say the least but with years of self denial & practice i completed it without any problems , i then carefully slid a ground down Allan key into the hole and unscrewed the remaining threaded sleeve , I never in my wildest of dreams thought it would be threaded and welded up . I drilled & tapped the anchor with a new bigger 3 mm thread and inserted a new precision high quality stainless steel rod .Then put a clearance drill throught the other leg's adjuster stop anchor .
Next came the amusing part . Trying to get the shouldered fulcrum pin back in the legs and inserting them in the spring " C " clamp.
After four or five failures I managed it by holding the legs , interesting them in the clamp , then carefully slipping the fulcrum pin in as far as it would go between the legs . Then using a screw driver whilst the clamp was pressed against a wooden stop I gingerly levered the fulcrum pin up the legs till it gave that joyful " Click " as it slid home where it should be.
Turning up the new adjuster nut was interesting and so was trying to set up the " bump " style knurler , instead of messing around I used 3 mm Nylock nuts for the stopped ends .... result success.
Buoyed up by this success I decided to make the top axle pin for my pair of dividers .. nothing much to it or so I thought at the time . In 25 minutes I'd turned a bit of mild steel bar to the chosen diameter , carefully knurled it without wrecking it or bending it , turned the major due diameter for the securing nut .
Rather than try and use the parting tool to part it off I stopped the lathe took the carriage to the right slopped on a pair of soft leather gloves & laid a large soft old towel over the bed to catch the part when it became free . After six strokes of the hack saw I heard it change to the nearly cut through sound , one more stoke and it came free . Then bugger me if it didn't roll along the top edge of the hacksaw blade to the back of the lathe and went off down behind it in old might use this one day metal. " $%&")~~¬ it " I cried & called it a night . I'll just have a few minutes rummage in the morning and I'll complete the job .
Little did I know that the evil man cupboard trolls and gremlins would conspire against me over night and hide it well , infact so well that I ended up having to strip out that side of the garage before I found it nestled between the white water pipe and the garage wall , long long after I'd searched ,brushed and wiped down every sodding bit of plastic , metal , machinery and wood . & having vacuumed the floor twice and still not finding it.
Such are the trials of life for hard working folk . Part of the garage contents enoying the sunshine .
The utter devastation of the rest of the garage inside ... note the white water pipe on the wall .
Seven hours later everything was put back in a better order & I finally assembled and tested the dividers , having first gingerly drilled &7 tapped the " C" spring for the new 3 mm thread or the axle .
Result... an astounding success for the day in more ways than one.
P.S.
I'm having today off , I deserve it .
Round in circles
Jul 9, 2014
606
P.S.
sgisler
Feb 27, 2012
369
I've been trying to decide how how to mount DROs on my 10k. This gives me some ideas!
Stan,
chevydyl
Jun 15, 2013
1,199
On my atlas 12" I had to mount the x scale on the chuck side of the cross, I'll post a picture later of it, I used yuri (spell) touchdro, turned out great, but I had to remove it for a certain job and haven't installed it again lol
roadie33
Dec 11, 2014
866
Great idea.
That is a good place to put the DRO so it's out of the way and protected.
I'd have to do some modifying to use my Taper Attachment without removing it.
jwest7788
Active Member
Apr 20, 2015
50
Got around to finishing my mini DRO's (I made three, each with a different magnet arrangement on the bottom to be sure I don't run into a situation where they cannot be used.)
D
Deleted member 31249
Guest - Please Register!
I had started a couple small projects before going in the hospital and finished them after getting home last week. I am only allowed in the shop for short times right now, but got these done.
i wanted square collet holders for the T&C grinder I built but was not going to pay the high price for the square 5C collets. I took a piece of 1/2" x 1" CRS and milled a 5/16" slot in the center of it .150" deep. I then cut it in half and sandwiched it over a 5/16" lathe bit to keep alignment. I chucked it in the 4 jaw and turned the body round at .625" diameter.
finished collet halves.jpg This is the two finished halves .
tool holder inserts and bit.jpg The tool bit fits here.
square collet holding bit.jpg The assembly fits in the 5C collet and the square end is used to set a level on to set the tool square, then the proper angle can be adjusted by turning the work head on the grinder. This was an easy inexpensive solution to grinding lathe bits on my T&C grinder. Now to make one for 1/4"and 3/8" bits.
The other little project was a friend gave me some tool insert holders and inserts. I cut some CRS and made holders for the insert ends.
milled pockets in tool holders.jpg I milled a pocket in the end of the 1" square steel bars. I used a carbide burr in my Dremel to square the inside corner.
inserted tool holders.jpg I drilled a 1/4-20 hole at a 22.5 degree angle and mounted the insert holders in the pocket. I then (as seen in the right side of the photo) cut the thickness down to .700" so the tools fit in my QCTP holders.
finished tool holders.jpg This is the finished holders. Since he gave me three insert holders , I went ahead and made three tool holders.
finished inserted tool holders.jpg This is the finished set. They are really nice considering I have NO money invested in them. I rarely use carbide tools but do need one once in a while. At least I will be ready when I need one.
roadie33
Dec 11, 2014
866
Mark, What kind of insert holder are those and where did he get them?
D
They were made by Sandvik. I don't know the model number,( it is probably printed on them). but I have seen them on ebay also. I don't know where he got them but he gave me a bunch of tooling like drills and reamers and these to do a little machining job for him. They mount in different types of holders made by the manufacturer, but I thought they would work great for the tool holder I made ( and they did).
Round in circles
Jul 9, 2014
606
:cheerful:That's a lovely job there JW . Now all you have to do is sort out that godawful noise that your lathe is making ... ;):D
chevydyl
Jun 15, 2013
1,199
here is the picture I promised of my scale mounted on the front of the cross slide, atlas put the gib screws on wrong... would have been much nicer with a tapered gib setup
davidh
Jan 23, 2012
1,217
nice clean job. are you going to make a shield for it to keep the cuttings and swarf from getting on it? it'd be a good idea as it appears to be dead under the cutting tool. . .
D
I was wondering the same thing. It is going to get hit with all the cuttings and fluids and stuff. A shield may be a necessity here.
Nice job though. And looks good
chevydyl
Jun 15, 2013
1,199
Last time I used it I would just put a piece of cardboard over it, like is aid it's not even mounted anymore, I took it off for a job and said, do I wanna put that back on? Nah
roadie33
Dec 11, 2014
866
If you can find the numbers on them I would appreciate it. The ones I find are to large for my holders.
D
I have several of the large ones, but they are too big for my use. If someone with a big lathe can use them, I will give them to them.
roadie33
Dec 11, 2014
866
That's the same problem I have Mark.
Looking for the smaller type for 5/8" or 3/4" tool holders.
I can find plenty of the 1" on up.
chevydyl
Jun 15, 2013
1,199
Hey mark, I wonder if one of them do dad's would be complimentary to a radius turner build I wanna start here soon...
D
I'll see what I can do and get back to you.
brav65
Sep 24, 2014
925
Great looking grinder. Can you post how you did your wheels and how much crown worked for you?
In a Tom Lipton video he showed a grinder he built and he used 2 degrees for his tracking wheel. I think it worked as the grinder was 25 years old and had been used in a production shop for a number of those years.
D
The numbers on the smaller ones are:
ULTRA DEX Tooling Systems
C-WT-001
UTS-105241
I tried to find a web site for these but had no luck.
Status
