Potd - Project Of The Day- What Did You Do In Your Shop Today?
Status
Not open for further replies.
bosephus
Jun 25, 2014
450
Todays project isnt as involved as some others .. but i had a few extra minutes .
Started making a new compound clamp for my g0602 .
Ill get some holes drill and tapped tomarow .. total time invested will be under 90 minutes if everything goes as planned
drs23
Jun 18, 2013
702
This isn't going on anything for NASA but a Shovelhead I'm finishing up a 'frame off' on. The owner wanted to sprinkle in a few brass bits in memory of his brother. I sourced the kicker pedal he wanted and found a brass oil bag plug as well. The tranny fill plug was just butt ugly so :brightidea:.
I knew I had one little piece of brass round stock.
So I started with this:
And found this hiding in there (These things have a tendency to seep around this plug so I cut an 0-Ring receiver groove):
Here's the 35yo OEM piece being replaced:
And here it is at home:
I got to use my brandy new Aloris knurling tool that was given to me a while back. It sure beats the scissor type that came with my import tool holders to heck and back.
Thanks for looking.
F
f350ca
Forum Guest
Register Today
Assembled one of the short wall sections in the shop today. Thought it might help to have the overhead crane for the first one, looks like they're going to go together and square up pretty easily.
John Hasler
Former Member
Dec 8, 2013
2,651
Found a fairly nice 3/8" drill chuck with a beat-up integral shaft in my inherited junk and made it usable on my mill.
The shaft was about 4" long and .530" diameter. I put a chunk of 1/2" shaft in the spindle chuck on the Logan and turned an inch or so of it down to .375". I then clamped the chuck on it and checked the runout on the shaft: about .015 out 3". Center drilled the end of the shaft, stuck a center in it and then turned the shaft down to .500". Cut it off, polished it until it fit a 1/2" collet and stuck it in the mill. After a bit of fairly gentle adjusting with a rubber mallet it shows .001" TIR on a precision pin close to the jaws.
Tomorrow I'll stick something long and straight in it and see how much it wobbles out a few inches.
F
f350ca
Forum Guest
Register Today
Have the timber frame on my shed assembled, now for a roof.
Greg
woodtickgreg
Jun 22, 2012
1,552
Very cool Greg, I am enjoying watching this, thanks for taking the time to post for us.
jmhoying
Apr 21, 2013
204
Greg
Greg,
That's a good looking frame! I did a bit of timber framing about 30 years ago. Built a couple large shelter houses for a park, and did all the actual cutting and drilling at a historic themed festival. The lumber was cut at a sawmill to 8x8s, 4x4s etc, but all the other work was done on-site with only hand powered equipment. An older gentleman who built many barns in his younger days taught us a lot about using a square for simple and quick layout. Amazingly enough, when the parts were assembled a few weeks later at a different site, everything fir!
Jack
Fort Loramie, Ohio
F
f350ca
Forum Guest
Register Today
Thanks guys. Was a fun project but can't imagine me doing it all by hand Jack. Spent too much time last winter digging through the snow to find stuff, hopefully this will help and finally give the tractor some shelter from the elements. I sawed the 6x6's from red pine that was knocked down in a storm a year ago, a couple of afternoons and I had enough logs home. Some of it was stained in the log, then the pile stained this summer with all the rain we received. A couple of big white pines had to be taken down at the local cemetery, I was offered the logs, they yielded enough 1 x 10 's for the siding, so the building so far has only cost me the ties I put on the ground and the doweling to lock the joints and a bit of diesel fuel for the tractor and sawmill. Unfortunately now I have to buy material to put the roof on,
Greg
Bill C.
Mar 11, 2013
1,390
I like inserts too. They beat those helicoil thread replacements any day.
Status
AdBlock Detected
I've Disabled AdBlock
