Potd - Project Of The Day- What Did You Do In Your Shop Today?
Status
Not open for further replies.
Round in circles
Jul 9, 2014
614
Mark ,
Did you try to heat the spike from room temp using both methods ie with & without the shim ?
If you didn't and now do it will you tell us the best timed heating result please?
eeler1
Dang, buggered that up too!!
H-M Platinum Supporter
Mar 7, 2014
641
Nothing fancy, no flames, trailers, backplates, or similar fine work to show, actually no pics. But, did pull the apron off the Logan lathe and put some liquid gasket material along the bottom between the clamshells. been meaning to do it for a while now, as otherwise all the oil leaks out of the apron in short order. Messy and a waste of oil. I'll fill it back up tomorrow and see how well it sealed.
chevydyl
Jun 15, 2013
1,199
Be careful with heat and concrete, I've seen it pop chips out from direct heat. Badass burner though, I'm gonna make mine out of a microturbine fuel nozzle/injector as I was able to score a couple from work that had been used but not used up
BillWood
Aug 28, 2013
165
Succesfully cut 1 1.5" 8tpi external thread and a 1.5" 8tpi internal thread.
This duplicates my spindle nose and helps gauge things in future. No need to remove chucks faceplates etc just use these things.
Was amazed at how a relatively tiny piece of swarf jammed the threads - thought I'd made a mistake in cutting them but a close look revealed a tiny piece of swarf that hadnt cut properly and was still attached to base of the V in internal thread.
And now the big job - This was a practice run prior to reboring a couple of Myford faceplates to 1.5" and cut 8tpi to fit my 9" Hercus (SB clone)
kingmt01
Apr 29, 2015
899
Nice work on the backing plate & I so agree on the cast. I hate working that stuff.
T Bredehoft
Dec 27, 2014
3,860
No pictures, but I've done all I can on my lathe toward making a 4 tool post which will mount on the saddle, not the compound. It will be far more solid than the original Lantern Post. Now, Matt, I need my PM25.
markknx
Apr 1, 2013
1,142
Mark ,
Good Idea. I will try to do this tomorrow. I have a few spikes so I don't have to wait to cool them down
kvt
Oct 21, 2014
2,124
Mark,
you may have the same problem I had when I built a foundry out of an old propane tank, it will have to be readjusted. Burners like that produce a lot of heat, and yours looks better than mine.
and mine melted some cast iron., Left if a to long in the wrong spot, as I had a hot spot.
markknx
Apr 1, 2013
1,142
Kvt, not sure what problem you are talking about. too much heat? or readjusting it? I am sure the whole forge is going to be a learning curve. the good thing is really if I get hot enough to forge weld it will be good. If I can maintain a fairly steady heat even better. if I get a real control of the heat awesome. because then it can be used to temper. The regulator will allow me to control the burner but heat build up may make it hard to hold low heats at a steady heat. 450-800.
Mark
Status
AdBlock Detected
I've Disabled AdBlock
