- Apr 12, 2013
- 562
A simple project compared to a lot I see here, but it brought a favorite tool back to life so I have to share. This old reloading powder measure had a thin plastic reservoir. It was brittle and falling apart. It was converted by a friend years ago to be a small volume measure, and I still get good use from it for small batches of ammo. So I bought a piece of 12" plexiglass tubing and went to town.
Lessons learned, plexiglass is a PITA to grip in the chuck. I probably should have taken the time to turn a block for the ID so it could be clamped firmly. As it was when the cutoff was finishing it grabbed, torqued at the chuck, and shattered about 2" of one end at the chuck. plexiglass WILL shatter just fine no matter what the propaganda about it being shatterproof says.
It was slightly undersize, so I had to turn a spacer ring. Thin rings are also a PITA to chuck. Very light cuts and sharp HSS did the trick.
It all slips together, tight enough it doesn't fall out when held upside down, but will come apart with easy pressure.
All in all, I am pleased with the result...breathing more new life into an old tool. Yes I still use it...for precision loads I throw a half grain short and trickle up on the scale...and the small measure is perfect for my small volume cartridges...
