power feed ?
On my way, making one.
I have just ordered one for x axis but when im home from work next monday for a few weeks i plan on building my own y axis one .What motor are u planning on using? I have some little dc motors with 60.1 reduction there only small but may just do the job .if not ill look for something a bit bigger .I have a 220 to 24v convertor and forward reverse switch and speed control box to so see what happens if the motor is not powerfull enough ill look at wiper motor .Intrested to see your set up when its done
I’m using a cardon 40-299 wiper motor that I purchase from Auto Zone. It is used on the larger size Ford pick up trucks. Cost 39 or 49 bucks, but it didn’t have a core charge. I watched Stefan Gotteswinters video on You Tube, and I’m following his lead. I removed the power supply from an old PC. 12 VDC 18 ampers. Then purchased a controller from E bay that has a rheostat and a forward, reverse switch. Let me know how your x axis works out.
