power supply for mig welder
quickcut
H-M Supporter - Gold Member
Apr 9, 2014
68
Good Day all. Is it possible to use an inverter welding machine, say a 200 amp one, as a power source for a diy MIG welder ?
327magrifle
Mar 15, 2016
1
If it will produce constant current. Constant amperage is for stick welding, but a suitcase wire feeder needs constant voltage.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
quickcut
Apr 9, 2014
68
Thanks ,I have never seen a an inverter welder (stick type) with a cv setting. Any body know of a make.
Ironken
Feb 19, 2016
326
With one caveat, some suitcases are CC/CV which allow them to be used with a DC "stick" machine. The suitcases that I have used that are CC capable have a voltage sensing lead that clamps to the work in addition to the ground.
Rustrp
Feb 6, 2017
536
I think the power source needs to produce CC and CV to power a CC/CV unit, suitcase etc, which would be used in a remote capacity.
Rustrp
Feb 6, 2017
536
What are you referring to when you say DIY MIG welder?
Ironken
Feb 19, 2016
326
I respectfully disagree. I have used suitcases in CC mode. The Miller 12vs is one such feeder. The Miller I used had a selector toggle inside the case to choose between CC or CV. The feeder varies wire feed speed to match the actual voltage being delivered from the power source.
FCAW and spray works fine in CC..... short circuit.....meh.
Rustrp
Feb 6, 2017
536
I stand corrected. Standing with my "I think." my following post was asking what DIY Mig welder, and which does make a difference. The electronic circuitry of the 12VS allows for more stability, but the favored flavor is DC. The older models like the S3S which are VS are not very efficient. Without knowing what MIG welder the OP will be using it's difficult to say yes.
Ulma Doctor
Infinitely Curious
H-M Platinum Supporter
Feb 2, 2013
1,151
The idea is sound in principle.
i have 2 PowCon Inverter Welders (300 amp and 200 amp units)
the 200 amp unit is my dedicated FCAW unit for steels.
300 is dedicated to SMAW
You can do it!
you'll need to make or buy a wire feeder for the power supply
Rustrp
Feb 6, 2017
536
You can do it!
It's been a while since I held a PowCon but I remember the units as early multi-purpose models before their time but hearty and reliable? i.e. Stick, TIG scratch and MIG/FCAW.
Ulma Doctor
Infinitely Curious
Feb 2, 2013
1,151
The units i have are the Jobsite, 70lb Breadbox on Steroids type.
they have been solid units
quickcut
Apr 9, 2014
68
Here is my dilemma, I have two mig welders , both are US. One has the wire feed psu board broken (sip 200 amp) and the other (afrox 200 amp) has a transformer problem . I was just trying to think of a way to get them both working. I could probably build one out of the other, but I was trying to get both to work .
magicniner
Oct 21, 2017
498
One has the wire feed psu board broken .
One of my two 1980s ESAB Smashweld 180 MIGs died earlier this month, no life at all when I turned it on and pressed Go.
I checked a grinder worked on the same outlet and checked the fuse in the plug, both OK.
Stripping out the control board revealed some of the polymer foil capacitors were cracked, figuring it was worth a punt I called in the local Maplin store and bought modern equivalents for the grand sum of £4.11 and fitted them.
That worked!
Had the caps not fixed the MIG I was considering replacing all the transistors on the board and if that didn't work replacing the board with a small relay to power the gas solenoid and a cheap DC motor variable speed control for the feed, this would lose the link between voltage and feed speed but if you can set up a MIG that's no issue really.
Regards,
Nick
AdBlock Detected
I've Disabled AdBlock
