Hi, I am wanting to try something new with my bladesmithing and need a little machining expertise. Rather than using small caged ball bearings on either side of the blade of a folding knife, I want to try boring a .5” hole through the blade and pressing a sealed bearing into it. The pivot will then go through the bearing. For a tight, permanent fit, how many thousandths smaller than the bearing should the hole be, and with the blade being .150 thick can I expect the bearing to be perpendicular to the blade on its own or are there measures I need to take to ensure this? Thanks
