I need to look at the other side of the table, one would expect a oiler there alsoWonder if it's worth putting a one-shot system on these little mills. Yours is almost identical to the one I just got, I'm sure you will enjoy working with it....
Me and a few others on this site have done a few mods to make the Rong Fu more reliable. There are a few big threads and lots of scattered posts on these improvements, but you have to dig around.
Here's a tip that I wanted to share since your first picture posts. I don't think head alignment jigs are necessary, but the head bolt upgrade made a world of difference:
RF-30 Clone Head Alignment Guide
Rob,- Now you have me going again, mine has two belts. Does three mean you have a power quill down drive?www.hobby-machinist.com
I‘ve got mine pretty well cleaned up, not quite like yours but much better than when I bought it. Why do you want to remove the table, does it need service or do you just want to have gone through everything before you start using it?Started out with thisView attachment 414414
Came out like this
Still figuring out how to remove the table.
Ordered gates belts and the head bolt kit recommended by
I found a ball oiler on the table, you can see it in the second to last picture above!
don’t think it will be that time intensive to do the table and let’s me keep my AR tendinitis intactI‘ve got mine pretty well cleaned up, not quite like yours but much better than when I bought it. Why do you want to remove the table, does it need service or do you just want to have gone through everything before you start using it?
John
Indeed there isJust the one oiler thats interesting, have you found one on the back of the table also ?
Stu
Correct on the oilerDeadGuy, the rear table oiler on mine is opposite the front oiler. Kinda hard to see.
your machine looks exactly like my Griz G1007 except for the color.
mine was made in 2004.
should be a date on the motor that will give close date of build.
