Problem #1
4R8
Aug 30, 2011
151
There would be a few methods i'd say?
What I'd use would be the known angle of 30deg from x0,y0 to the hole and this distance (hypotenuse) which is equal to the pitch circle.
This then treats it as a right triangle and simple trig can be applied to get the lengths of the other two sides.
I won't go through the formulas as I'm the first to view and first to reply.
PM'd answer anyway to check
Well, just looking at the drawing the only thing that I can come up with on my own, is that both the X and Y coordinates will be less than 1.5" each. (Radius)
Beyond that, I've got to go look for help. How sad is that? :eek:
never mind the first one Bill! I had a 1:20am (Oz time) moment and used 6 for the radius:headscratch:
Just resent with new figures, neither might have come through yet.
7 holes would be just nasty. Doable, but nasty (what would the tolerance be? :p)
Jason
At least I know I posted enough info to get this thing going. I wanted to make it 7 equally spaced holes but that would have been an exersize in futility. LOL
"Bill Gruby"
That is why my best friend's name is spelled D-R-O. :rolleyes:
Ok, I'm off to class again... :grin:
For fun (more so nothing else to do in the office right now) for 7 holes, same diameter, hole 'A' in the same location @ x1.5,y0
I'd work hole 'C' like this:
Work out the hole spacing as an angle value
360/7 = 51.4286deg
work out the angle at which 'C' is from 'A'
51.4286 * 2 = 102.8571
then the angle from the X axis
102.8571 - 90 = 12.8571
12.8571 then becomes your reference angle
sin 12.8571 * 1.5 = .33378
cos 12.8571 * 1.5 = 1.4624
Hole 'C' (with 7 holes) is @ x-1.4624, y.33378
I shouldn't have asked about tolerance on the circle as i had no idea how small a minute was until I Googled it.
They sure are a small thing (unless the circle is massive:rolleyes:)
Jason (with a headache)
OK, let's see if anyone knows how to do it without trig and math at all. You have the same print, a machinist's square, a machinist's scale, and a pair of dividers.
Some may know of this elementary method, so let the ones who don't think about it just a bit. And as with Bill, if you want, PM your solutions before posting them.
I don't know what a machinist square, machinist scale or dividers are! :headscratch:
I could do it with a compass, a square and a ruler. Or are these the same thing but of a lower accuracy?:huh:
Jason
Pretty much, Jason....but since this is a Machinist's forum, let's try to use the right terminology. ;)
Had a feeling that was the case but never looked into it- self taught in trig, machining, welding, mechanics, etc. (see the hobby part of the forum title?:p)
Square to find center of the block. 2"x2" to center. Scale to open dividers to 1.5". From center scribe a 3" circle. Use the same measurement as the radius to scribe 6 equal marks on circumferance because the arc is equal to the radius. This is why I chose 6 holes. Don't forget to blue it first.
Jason -- Compass = Dividers, Ruler = Scale, Square = Square.
"Bill Gruby"
^^What bill said.....
Then using the (machinist) square you can mark and or measure (including your machinist scale) your x,y travels :thumbzup:
