- Oct 5, 2010
- 1,043
I have an Enco model 120-6718 surface grinder. This is an old timer that is no longer carried by Enco. It was manufactured by Hanjiang Machine Tool Works in the PRC back in 1991. It is 220Vac 3 phase run on a RPC. None of the other machines running on the RPC are acting up. I only run one machine at a time.
Generally it runs well and does what it is supposed to do. The problem is that it will shut down on its own, some times while grinding and other times when it is just running free. Basically the motor will just shut off and spin down. Some times I can just hit the start switch and it will restart. Other times, after a few minutes, I will push the reset button and it will restart. This is becoming more and more frequent. According to the "Chinglish" manual the reset is on the "AC contactor" (Seimens 3TB41-17-OA). I am wondering if I should replace the contactor or if there is something else I should do to solve the problem. I am electronically challenged, so I really have no clue as to what to do.
I would appreciate any suggestions.
TIA
Randy
TIA
Randy
