- Aug 19, 2014
- 13
I purchased this lathe brand new just recently and I'm having problems with the cross feed. It will not under any
circumstances engage. I have tried pretty much everything under the sun to get it to work here are some pics and I'm
Praying that maybe someone out there has had this same issue. In the first picture you can see the gear is worn a bit
on the first 1/8th of an inch of the gear. That's were the big gear inside the carriage picture 2 is just bumping against it. The gear in the first picture
measures 1.164 to 1.176 round if someone out there has put these taper attachment parts on a 1440e-lb and has had the same problems or if possibly
someone can pull there cross feed dial out of there carriage and mic the gear for me to make sure its the right size I would be grateful beyond words because other then that I'm at a total
loss. Thanks for any help that anyone can give me in advance...
Negev
Negev
