[4]
Prusa i3 Mk 3
[3]
[10] Like what you see?
brino
Jan 2, 2014
3,477
Congratulations!
Are you going to document the assembly?
Even just a short write-up about how easily (or not) it goes together, and some info about your first prints would be very useful.
Thanks,
-brino
RVJimD
Dec 30, 2014
259
I had a mk3 kit ordered back in March but got frustrated with the delays and cancelled that and now I have two monoprice printers. One select plus and one mini! I have really been using both and I love to see a fusion 360 design come to life on the printer! Jim
GreatOldOne
#SaveTheExpanse
Mar 20, 2014
148
Pics from tonight’s assembly session.
Frame assembled.
Y-Axis assembled and installed:
Then the X-Axis along with the Z-axis lift motors and screws:
The extruder built and attached to the X-Axis. This took the bulk of the build time tonight, as there a lot of parts to put together, and cables to route.
Cable management on the rear of the extruder.
So far, the build has been a breeze, apart from some fiddly bits where M3 nuts have to be pressed into some deep holes. And the instruction book is amazing, you get a full colour printed book, and it’s in English, not some facsimile of the language. :)
Here’s the electronic version if you’re intersected.
https://manual.prusa3d.com/c/Original_Prusa_i3_MK3_kit_assembly
Tommorow I’m onto the electronics and power.
GreatOldOne
#SaveTheExpanse
Mar 20, 2014
148
LCD and bed attached:
Electronics enclosure and main board
PSU - where it’s attached allows it to double up as a brace dor the frame:
Cable management:
Wiring connected up to the main board.
Complete!
First print.
GreatOldOne
#SaveTheExpanse
Mar 20, 2014
148
Ok, so I tried to print out a benchy as it’s what all the cool kids do. This is what I got:
Not the best of results! :/
A quick call for help on the Prusa Facebook page, and I got a diagnosis - the belt pulleys where loose. This from several new friends - and - Jo Prusa himself!
After making the suggested tweaks (tighten the grub screws on X&Y axis, check the extruder filament tension, double check the initial layer height), here’s the result - ahoy there mateys!
I’m blown away by the quality of the print, and the level of support.
GreatOldOne
#SaveTheExpanse
Mar 20, 2014
148
My first “paying” gig... :p
These are some fasteners I designed for my friend, who in his spare time is the boatman at the local rowing club. He wanted some nuts making up to hold things in the racing boats (I forget what it’s for, but these are the same sort of 4 or 8 man boats you see at the Olympics and the Oxford V Cambridge race on the Thames). The crews have a tendency to do things up too tight, stripping fittings out the fragile boat shells and causing lots of grief and costs to the club. These are can only be done up by hand, and if they try and wail on them the nut will strip out of the plastic before it does any damage to the boat.
I’ve had the fusion 360 files sat on my laptop for ages, as I couldn’t get them to reliably print on my old delta printer. The MK3 romped through them.
They’re M6 nuts pressed into the bottom, and the text reads “HAND TIGHT ONLY”, just so the crews don’t forget. ;)
GreatOldOne
#SaveTheExpanse
Mar 20, 2014
148
So yeah, I’m now realising that the build is never over. Tinkering is habit forming, upgrades ahoy! :cool:
The_Apprentice
Staff member
Jun 14, 2017
248
Been keeping an eye on it myself. But I'll wait a few more months :p
GreatOldOne
#SaveTheExpanse
Mar 20, 2014
148
I've swapped out my security cams at home, and the base of the old ones where bigger than the new ones. And I didn't feel like filling holes and painting... So from problem to solution, about 2 hours. :D
Modeled in F360:
Exported, sliced and printed in black PETG - same dimensions and fixing locations as the old mount:
Recess takes a steel plate that came with the camera, fixed with VHB tape:
New camera has magnet built into the base, so it sticks to the plate:
And in place and on line:
Result! :cool:
GreatOldOne
#SaveTheExpanse
Mar 20, 2014
148
I've now got my printer enclosure built, and the printer relocated up in my study rather than on the dining table.
3 Ikea LACK tables, some printed parts and some perspex and you get a very handy printing station. :D
First print in the new home:
Frank O
Newbie
Feb 14, 2017
6
Great work with your MK3. I ordered a kit that arrived in late January, but due to major, unexpected changes to my schedule I didn't get the build completed until this week. Was happy to see that, after a couple of relatively minor tweaks (tightening a belt, adjusting height of the sensor on the extruder) I'm getting clean prints. Now my only issue is that I've managed to forget everything I learned about Fusion 360 over the past few months. So some major resharpening is in order there.
GreatOldOne
#SaveTheExpanse
Mar 20, 2014
148
More 3D printing fun - this time an ink stamp for my Aunt's crafting hobby:
I'll be in the garage
Newbie
Jan 13, 2018
2
For the printer enclosure you built--is that functional or aesthetic? I was just wondering about it the heat generation in the box if that would make taller parts sag, or if by maintaining the build area a little warmer you would get more even/slow cooling and hardening of the part? Looks good though, answers the question of where to store the darn things when you aren't using them. That second print of the boat came out great! I can barely see any layers.
GreatOldOne
#SaveTheExpanse
Mar 20, 2014
148
It’s functional... certain plastics really don’t do well with drafts and stuff causing diffent cooling rates of the part. This causes warping and possible printer crashes as the head hits a corner or other feature that has lifted.
I need to modify it though, as the MMU unit needs a little more headroom inside for it to fit nicely and for access to it.
jwmelvin
Active Member
Jan 11, 2018
124
Have you tried PETG? It’s pretty great in that it doesn’t warp like ABS but has better toughness and heat tolerance than PLA. I like it (using an i3 mk2S)
FLguy
Jan 11, 2016
257
I'd like to see 3D printing group here. I have a Flying Bear Ghost... well built unit.
FLguy
Jan 11, 2016
257
Oh Oh, not paying attention again. Guess I need to look around a little before I say something.
GreatOldOne
#SaveTheExpanse
Mar 20, 2014
148
Yep. All of my enclosure parts where printed in Black PETG.
[6]
[5] [7]
