PTO reverser gearbox
OldMachinist
Bronze
Rest In Peace
Mar 1, 2012
1,140
The farmer who leases my fields asked me if I could build him a gearbox to reverse the direction of the power take off of a standard tractor. I said sure if he buys the material. Well here's how it came out.
I didn't take pictures of the normal machining processes like squaring up the material, drilling, tapping and dowel pin holes.
After that work was done I drilled and bored the gear center to center distance thru the bolted together blocks.
Then it was off to the lathe where it's a lot easier to bore and face.
Then back to the mill to clean a little out of the sides.
Again I didn't take any pictures of the standard turning/boring of the shafts and gears. But I did take one of putting a keyway in the gear with a bar I have that has a clapper box on.
8ntsane
Dec 1, 2010
1,172
Looks like you did a fine job of that. He should be a happy camper, er farmer ;)
Metalmann
Jun 3, 2012
231
Excellent job, OM. I see you also use HSS tool bits on your 4 jaw.
I think you did that job too cheap, that's a lot of set-ups for different operations.:whistle:
Just kidding, I also do those jobs for local farmers, sometimes bartering for fresh, farm eggs; and pork, lumber,...etc.
Again, fine work.
jgedde
Jun 23, 2011
787
That's sweet!!! I really like to see that it was made without CNC. I also like your broaching tool. I borrow broaches from work for that, but I will certainly reconsider my method! The splined shafts are simply beautiful...
Another POTM winner???
But, all the farmer needed was an Asian belt. Those spin backwards... :rofl:
John
OldMachinist
Bronze
Rest In Peace
Mar 1, 2012
1,140
Yes, high speed tool bits make nice spacers when you need them. That jaw wouldn't close without hitting the other jaws so it got the spacer.
The materials cost a little over $270 so I didn't charge him anything besides he always brings me fresh produce from his garden.
I'm waiting on some material to put seals/covers on the shafts that won't be in till next week.
OldMachinist
Bronze
Rest In Peace
Mar 1, 2012
1,140
I haven't given it to him yet because I need to make the plates to put lip seals on the shafts and covers for the opposite sides. I'm planning on 90 wt gear oil in it.
I have broaches and mandrels to do keyways but my press is in another building so if I don't feel like walking over there I just use the bar in the lathe to shave in the keyways. It doesn't take very long to do it that way. I take about .0025" per cut and do a float pass every three or four cuts.
Terrywerm
Jan 16, 2020
7
I know this is an old thread and everything, but I have to ask: How did this gearbox attach to the PTO on the tractor?? Secondly, what type of attachment was he planning to run in reverse?? Since the gears are not very large, I assume that he is not planning to transmit much power through that box.
OldMachinist
Bronze
Rest In Peace
Mar 1, 2012
1,140
A PTO shaft will drive the gearbox. I havn't seen the attachment he's planning on driving but I think its a screw type log splitter. Deer season got in the way of me finishing this project. I'll get back to it in a couple of weeks.
Michaeljp86
Jan 2, 2013
173
If you can post some pics when he uses it, Id like to know what hes using it for.
dwdw47
Jan 9, 2013
41
Good job on the gear-case, as a lube I'd use a Molybdenum high pressure grease mixed with the 90 wt. those gears are small and will run hot if their loaded.
When you help the farmer install the gear-case make sure he uses a least an arm or pair of chains to hold the box from spinning around the drive gear( I assume its for the PTO).
It's embarrassing to just give a farmer piece thats a new modification.
Just my 2 cents
dwdw47
awander
Jun 21, 2013
318
Where did you get the gears that you used in that gearbox?
OldMachinist
Bronze
Rest In Peace
Mar 1, 2012
1,140
They're Martin S1236 stock gears that I bored and broached. You can get them from any bearing/power transmission supply house.
awander
Jun 21, 2013
318
What is the approximate cost on them, if you remember?
thanks,
genec
Mar 15, 2013
256
I believe we had something like that when I was a kid but it was about half the size of a bushel basket and I believe that also had a chain attached to it and the tractor draw bar to keep it from twisting. It was factory made. Good job.
shark_bytes
Sep 16, 2014
2
Very nice work.
Was wondering if you still might have a blue print on this? I'm in need a similar part.
I'm restoring a 1963 Chevy C50, and have added a dump bed. The hydraulic system is vintage Chevy.
My problem is the pump charges counter clockwise, and the PTO drive is clockwise.
Your design will fix my problem..
There are some differences. I need the input/output shafts to both be .75 with .25 flat key way.
These will attach to u joints.
If you have a interests in making another one of these gearboxes, I would be grateful.
If not, do you know someone who is making a similar part? This is a kink in my completing the lift bed.
Best regards
shark_bytes
AdBlock Detected
I've Disabled AdBlock
