Good job on the gear-case, as a lube I'd use a Molybdenum high pressure grease mixed with the 90 wt. those gears are small and will run hot if their loaded.
When you help the farmer install the gear-case make sure he uses a least an arm or pair of chains to hold the box from spinning around the drive gear( I assume its for the PTO).
It's embarrassing to just give a farmer piece thats a new modification.
Just my 2 cents
dwdw47
Just my 2 cents
dwdw47
