- Sep 23, 2010
- 619
I do a lot of these shotgun barrels for my dad. The semi auto's need a hole or two drilled inside the barrel ring and of course its on an angle. The pump shotgun barrels will work with the hole(s) added. He was using a guy in Akron but he quit doing them on his mill because the setup was to hard or he broke too many drill bits. Well i set them up on my lathe with my cross slide hole driller and a cheap pawn shop drill and i haven't broke a bit yet. Its prob 10 minutes from start to finish. I use a center drill to spot where the hole goes then switch to a regular drill bit. I have some pics of a barrel with 2 holes but i don't have it on my computer....Bob
