Put Mach3
OakRidgeGuy
Oct 6, 2012
486
On the computer, how do I test that it works with it not connected to the machine?
just hit reset, then press offline. and load and run your code
if your wanting to see if the driver is working, in the mach3 directory run drivertest
steve
says that no driver sensed installed. run driver test.
ok.. under MDI I set in a example from the pdf file about Mach3, and it appeared to run, does that mean that it is working?
ok figured it out.. the desktop will not allow the drivers to load and install.. so I am about determined to try the next step..
I am going to have to get a copy of 7 pro before I can contiune with the computer.
Ok.. got virtual PC and XP mode on the desktop. reinstalled mach3.. did the driver test.. opened mach3.. opened "Mill" , did the "teach" example in the introduction and config pdf..
on the MDI screen
I hit the teach button
entered
g21
f100
g1 x10 y0
g1 x10 y5
x0
yo
then hit the stop teaching button
hit the load/edit button
went to the program run screen
hit start cycle
in the tool screen the lines show up.. but nothing happens in the DRO screen..
