- Jan 2, 2014
- 8,850
hope I have not screwed myself forever by starting on 'educational.'
....just tell them you recently graduated!
-brino
q20v
Thanks for your positive response. Just to be clear I am not saying that there is a problem with either style of T nut.
However, when I faced the same situation of mounting a new QCTP without the capability of milling the blank, I opted to use the existing round T nut and save the new square blank for posterity. I did not see the point of having two round T nuts.
It did require that a new bolt of the proper dimensions be threaded to fit the old round T nut and that was a fun exercise in itself.
It turned out to be relatively easy to do a bit of milling on the lathe. So I have both style nuts now.
Looking forward to seeing the results of your analysis.
Not hijacking the thread but a question about the round base in the picture.
Just a thought but the square style would be more rigid than the round one.
