I am interested in two machines which I consider to be within the limits of affordable equipment. The Taig micro lathe, and the CX 704 offered on busybeetools. I would like to make a cylindrical part starting from a piece of pre-hardened, or, alternatively, a piece of steel round stock with sufficient carbon levels as to allow hardening using applied heat.
The part would have a final overall length of 131mm. Of that length, 53mm would be turned down to an outer diameter of 13mm. The remaining length would have an outer diameter of 26mm. A 5.5mm drill bit would be used to create a hole 100mm deep in the center, starting from the larger side of the piece. Then, starting from the larger side, a 9mm drill bit would be used to re-bore the 5.5mm hole to a depth of 76mm.
I am wondering if all of these operations could possibly be performed accurately on either of the aforementioned machines. Any insight will be much appreciated.
