Question For Anyone That Has Done G0602 4-6 Bolt Compound Mod
RegisG
Mar 25, 2016
65
If you've done the mod to strengthen the compound mount, I have a couple questions:
- Is there any reason not to make the length long enough to be flush in front and almost reach the oil ports on the cross slide on back?
- Is or would it be helpful to drill a hole for the cross slide backlash cap screw? Or, would you always just take mount off the adjust when necessary?
I really enjoyed the helpful posts about this. Would appreciate any other tips on this.
Thanks,
Regis
Regis,
I made mine more or less square using the two original holes plus four new ones on the corners.
I used 5/8" steel plate. I also tapped six additional holes at the rear of the cross slide to permit an auxillary mount to the rear. I had to move the center oil port forward.
There is plenty of rigidity with this mount. I also added three additional holes to the dial mount.
I am on vacation now and don't have access to the design but can post it when I am back later this week
