question
rambin
Jul 29, 2013
237
will an 820 saddle sit on a 700a bed? just curios if I can change to the better apron with the clutch for my 700 wards model.... found a 820 being parted out. anyone do it?
Sure a Logan guru will be along shortly.thinking you'll have to change lead screw also unless yours is slotted .dont think it is.also you would need cross slide besides apron. 820 has gearbox best I remember.you would need it too to go with lead screw off 820.not sure if banjo is same on both..good luck..be a nice upgrade..
the screw on the 700 is slotted. was hoping to use the lead screw off the 700 just change the apron and possibly the cross slide. my 700 doesn't have a gear box its change gear.. anyhow looks like the 820 parts I had found fell thru so its just a pipe dream again
