[4]
Quick question on fly cutter build
[3]
[10] Like what you see?
U
umahunter
Guest - Please Register!
#1
When cutting the tool slot it needs to be offset so the tool tip lines up with the centerline is that correct
T Bredehoft
Dec 27, 2014
2,787
Likes
2,133
#2
You got it.
U
umahunter
#3
Thanks just wanted to be sure
T Bredehoft
Dec 27, 2014
2,787
Likes
2,133
#6
Just like a lathe, the tool has to be on center. If its below or above, it won't cut right.
P. Waller
H-M Platinum Supporter ($50)
Mar 10, 2018
796
Likes
527
#7
You have had this experience?
A tool held in a lathe is cutting on a radiused surface a fly cutter is cutting a radius on a flat surface, think of a flycutter/face mill as a rotary shaper tool which has no center of motion. It is indeed good practice to keep the cutting edge on the center line of a mill spindle however it will still work fine if it is not.
[6]
[5] [7]
