Eddyde wrote:
It is the same lathe as Joe Pieczynski and yes, it's 3 phase, I think they all are. I was also thinking of getting the 15" version, which is more common and of course more more expensive, but this one popped up close by and...
-That's Quite a story! You are your friend were quite "creative" (and "brave")!
Eddyde wrote:
I built a RPC to run my lathe as it has 2 motors, spindle and coolant pump. VFD's don't do multiple motors well so 2 would be required and rewiring would be necessary as I waned to use the original controls. Also the lathe has 16 speeds which is more than enough fo me. You might want to consider the RPC approach as well. Not that VFDs are bad, I have 5 in my shop, they are just not best for everything.
-Thank you for the suggestion. I don't yet know the difference between RPCs and VFDs, but I'll try to do my own homework before I ask any questions.
By "2 motors spindle" do you mean "2-speed motor" (I noticed a 2-speed motor was an option for the lathe)?
Thanks!
Bill_729
Thanks!
Bill_729
