Razor Sharp Edgemaking System
mikey
Global Moderator
Staff member
H-M Lifetime Diamond Member
Dec 20, 2012
7,297
The Razor Sharp Edgemaking System 8 Inch Deluxe Blade Sharpening Kit – a quick Review
Not too long ago, @mickri started a knife sharpening thread and after that discussion I pretty much resolved to find a way to sharpen knives, despite the fact that I totally suck at it. I wanted a knife sharp enough to produce a translucent tomato slice without holding the tomato down on the cutting board. To me, that is a sharp knife and I could not produce an edge that will cut a stupid tomato like that. What’s more, I needed to be able to sharpen my wife’s favorite serrated MAC knife without damaging it.
I did my due diligence and looked at many of the sharpening systems currently on the market. Some, like the Wicked Sharp system, were attractive but are way too expensive for my simple needs. Then I happened upon the Razor Sharp Edgemaking System and it looked really good – power driven, fast and many of the enthusiastic reviewers were knifemakers that said it produced good results. I figured if anyone would know what worked it would be a knifemaker so I jumped.
The system consists of two 8” diameter wheels about ¾” thick made of compressed paper that is intended for use on a 6” bench grinder without wheel guards and tool rests. One wheel comes coated with 180 grit Silicon Carbide particles; this is the cutting wheel. The other is a slotted wheel that is loaded with a white buffing compound by the user; this acts like a powered solid strop. The wheels will fit either a ½” shaft with the supplied bushing or a 5/8” shaft. The fit on the shafts is very good – no slop. The kit comes with some wax that is applied to the gritted wheel, some white buffing compound for the slotted wheel and a small tub of 180 grit carbide grit to renew the cutting wheel when needed.
Woodworkers have used similar set ups using shop made MDF wheels for years; this one differs in that it comes with a pre-charged cutting wheel. I think this is simple enough to make in your shop but by the time you buy the materials it might just be cheaper and easier to just buy the kit. I bought my set from Amazon. It is cheaper from Grizzly but with the free Prime shipping I think it’s a wash.
My old Craftsman bench grinder has two Norton wheels that run smooth and vibration free. It is used to sharpen my gravers and I was loathe to sacrifice this capability by touching the wheels so I decided to buy a new Jet JBG-6A, a 6”, 1/2HP bench grinder on Amazon. I bought this grinder instead of a cheaper one because I wanted a good machine right out of the gate and the Jet did not disappoint. Out of the box with the included stock wheels it ran smooth, quiet and without a hint of the vibration that seems to be included with cheaper grinders.
I removed the wheel guards and installed the Razor Sharp wheels one at a time, indexing each one 1/8 - ¼ turn at a time until I found a position where it ran smoothly. Jet hand grinds their wheel flanges so they are vertical when installed and I think this helps to reduce any wobbling at the wheels. Under power, both wheels run without a hint of vibration.
There was no need to dress or otherwise alter the Razor Sharp wheels before use. I applied a sparse coat of wax to the gritted wheel and some white buffing compound to the slotted wheel while turning the wheels by hand. Not much of either stuff is needed and the system was ready for use.
I should bring one thing to your attention right off the bat: any edge must face in the direction of rotation of the wheel. That is, with the wheels running in the normal direction, which is towards you, the edge of your knife must always face down. If you touch the wheel with an edge facing up it will catch and the knife will be forcefully thrown down and possibly out of your hands, and then probably into your foot or some vital organ. Please be mindful of this.
One thoughtful Youtube reviewer turned his grinder motor around on its base so the wheels rotated away from him and I thought that was a good idea because if he lost control of the knife it would be thrown away from him. Intuitively, this made sense so I decided to do that, too. For my first attempt, I chose to sacrifice my most used and abused Chinese folder that I got as a freebie from some forgotten mail order thing. The blade had this attractive multi-hued coating like the titanium blades get when heated; cheap but a nice touch and I sort of liked how it looked. I approximated a 22 degree angle and promptly ground the coating right off the hollow ground part of the blade instead of the edge! It turned out that running the grinder in the reverse direction made it difficult to sight and maintain the correct blade angle and I couldn’t see the point of contact well, at least in my newbie hands that were extended out in space with no support.
After much laughter and acknowledging my suckability, I quickly restored the motor to its normal direction of rotation and was then able to brace my arms against my body and sight down on the blade. This made it much easier to see the angle of the blade and the point of contact. THEN I was able to grind the edge much more accurately.
It turns out that the bevel of a blade is a compromise, like most things in life. The sharper the bevel, the sharper the knife but the more fragile the edge becomes. A fine sashimi or vegetable knife might do well with a 10 degree bevel but it won’t last long chopping through the backbone of a fish. Similarly, the 22.5 degree bevel of a general purpose knife may work well for most kitchen jobs but won’t last chopping wood like that 40 degree axe will. So, the bevel is a compromise and I decided that most knives in my house will work just fine with a 20-25 degree edge angle. My sashimi knife will have a 10 degree bevel.
So, how do you get this edge angle without a tool rest? That was my big question and it turns out that you can do a fairly good job of it by eye. The Razor Sharp guy tell you to do it by halves: half of 90 degrees is 45; half of 45 is 22.5, and you can eyeball these angles surprisingly well. With a bit of practice, you can even do it pretty consistently and this is made much easier when you can brace your arms against your body and look down on the blade to see your blade angle. This sight picture also allows you to keep the edge parallel to the face of the wheel, even when you raise the handle of the knife as you follow the curve at the tip of your knife.
It takes very little pressure to grind knife steel, especially when an edge already exists. I found that I simply needed to put just enough pressure on the blade to keep it in contact with the wheel and it cut quickly. This allowed me to relax my hands and that helped me to work more accurately. The light pressure also generates very little heat so losing the temper on a fine knife is a very low probability. In most cases, the blade doesn’t even get warm unless you’re grinding out a nick; then it only gets slightly warm.
Grinding out minor nicks and edge defects is very quick and easy but for a serious nick I think I would use a 120 grit belt on a belt sander instead. I had one kitchen knife that had a small nick and it came out in 6 passes over maybe 90 seconds on the carbide wheel.
When sharpening a knife on these wheels, you grind one side until you create a continuous bevel, then you flip the knife and grind a matching bevel on the other side until you raise a burr along the entire edge; this tells you that the two bevels are meeting at the middle to create a sharp edge. On most of my knives, this took maybe 2-3 passes on each side. Once you get that burr, you switch to the buffing wheel where the process is repeated but this time you are just looking to remove the burr. When that is gone, the knife is sharp enough to be suitable for most purposes, including shaving hair; I have the bald arms and legs to prove it.
This system is also very effective for serrated knives. My serrated knife is beveled on one side and is flat on the other. You sharpen the beveled serrations with the corner of the wheels and remove the burr on the flat side by running it on the center of the buffing wheel with the blade held vertically; this stays dead flat if you hit the center of the wheel. Or you can hone that flat side on a stone if you prefer. The resulting edge is scary sharp but it took less than two minutes to do … a very pleasant surprise.
I wanted my kitchen knives sharper than they are coming off the wheels, sharp enough to scare a tomato. For this, I needed a strop and I didn’t have one. When I looked into it, it seems that the guys most knowledgeable about them are the straight razor guys and the chef knife sharpening guys. If you read their forums it is almost as entertaining as a machining forum, complete with competing opinions from folks who know they are dead right. Anyway, I ended up making a two-sided strop using vegetable tanned cowhide contact-cemented to a 2” thick X 3” wide X 10” long block of MDF. I worked in a layer of MAAS metal polish on one side of the strop and left the other side clear. An edge stropped on the MAAS side comes off with a mirror finish that is then refined on the clear side of the strop. It takes only a few ounces of pressure and the correct blade angle to strop a knife and THAT edge is tomato-scaring sharp!
So, my knife sharpening search is over. I own some of the finest Japanese Waterstones sold and I own enough diamond stones to sharpen most anything but from now on the only system that will sharpen a knife in my shop will be this Razor Sharp system. It is very fast, cuts very cool, works better than anything else I’ve tried and it also sharpens serrated knives quickly and well. A strop helps to refine the edges and will delay the need for regrinding on the wheels; I now consider it an essential part of the kit. MAAS metal polish cuts very fast and produces a mirror finish in just a few passes; just one thin application to my strop finished the edges on every knife in my house and it’s still going strong.
If you are looking for a simple, cheap knife sharpening system, have a look at the Razor Sharp system. If I can use this system to sharpen a knife then anyone can do it.
Tomatoes and cabbage cores now fear me and I look forward to seeing how my knife carves a turkey. Don’t think too much about it – go buy this thing!
darkzero
Global Moderator
Staff member
Nov 27, 2012
6,427
Nice. I've always wondered about people using paper wheels. Those look like pretty quality made wheels than the ones I used to see.
I'm a pocket knife enthusiast/collector. If I didn't already own a Wicked Edge & a Ken Onion Work Sharp w/ the blade grinder attachment for larger knives I'd probably give one a try. What I have are not cheap so they're not for everyone but I love them.
Great post as usual Mike!
mikey
Global Moderator
Staff member
Dec 20, 2012
7,297
Thanks, Will. Yeah, for a klutz like me, this is more than good enough.
darkzero
Global Moderator
Staff member
Nov 27, 2012
6,427
Klutz, haha yeah right. Sharpening free hand requires a steady hand & skill/practice. Not any "klutz" can do that. Knowing you I highly doubt you of all people can be considered a klutz at anything that is power tool related. :big grin:
mikey
Global Moderator
Staff member
Dec 20, 2012
7,297
Thanks, Will. It took just a short time to get the hang of this thing. By my third knife, I had it down and was producing an edge that is very close to a factory ground edge. What really opened my eyes was the strop - that thing takes an edge from shaving sharp to scary sharp and I'm totally sold on its value. My wife even commented that her serrated knife cuts everything like butter, which is about as good as I could want and I'm happy.
Old Mud
H-M Platinum Supporter
Aug 8, 2016
406
Great post for sure Mike, I checked the site but couldn't find the suggested rpm. of those wheels.
mickri
H-M Supporter - Gold Member
Oct 31, 2016
1,025
As usual another great informative thread. Way to go.
Your way of holding the knife is very similar to what I now do. In one video that I watched the star of the video was shall we say quite rotund. He rested his hands on his protruding waistline and looked straight down on the knife. Very easy to see the angle of the blade and control the pressure of the blade against the belt. He named this the "belly rest" method of sharpening. While I don't quite resemble the star of the video I do have enough of a protruding waistline to make it work. One thing that I found helps to get the angle right is a match book. I use my 1x42 belt sander. With the sander not running place the match book between the blade and the belt and observe the angle. You now have a visual reference. You could also make some wedges out of the material of your choice.
The star of the video was using a 1x30 belt sander without the platen. His reasoning was that when sharpening against the platen you get a flat leading up to the the edge of the blade when you really want the blade slightly rounded leading up to the edge. I saw this mentioned in other videos too. Not wanting to remove the platen just to sharpen a knife I use the portion of the belt between the top of the platen and the upper wheel. Seems to work just fine for me. But then I am a knife sharpening klutz.
aliva
Feb 28, 2012
615
I'll stick to sharpening stones and a knife guide. So far it works well for me.
If you find a technique that works for you stick with it. The world is full of " The best sharpeners"
homebrewed
Jul 28, 2017
562
I made a sharpening jig based on the Edge Pro design. It looks like this:
The stone holders and mast pivot are made from Delrin. The bevel angle is set by adjusting the pivot (on the mast) height. That's handy because we have some Japanese knives that have a narrower bevel angle on them. The stone in the photo is a man-made 4000 grit waterstone.
The knife holder is a 2-piece arrangement, with a trimmed piece of "L" extrusion that captures the back of the knife blade, The extrusion is pushed down to hold the knife, then fixed in place with a couple of socket head screws. I made two holders, one for chef knives and one for paring knives.
While it works OK, due to the orientation of stone to knife it's possible to apply too much pressure and raise a bur you chase from side to side.
The brass handle on the holder does a good job of keeping the knife edge away from your hand.
mikey
Global Moderator
Staff member
Dec 20, 2012
7,297
They recommend 3000 - 3600 rpm. You can probably go slower; it would probably just take longer.
Aukai
Oct 4, 2016
2,050
The only thing I hate is my wife now wants her knives sharpened regularly. She never had a problem before, just made it work, now "the knife isn't sharp, can you......:rolleyes: Maybe the stropping will extend the life also.
I'll check this out, thanks Mike
mikey
Global Moderator
Staff member
Dec 20, 2012
7,297
... now "the knife isn't sharp, can you......:rolleyes:
Yeah, I was getting this a lot, too. My problem was that her favorite knife is serrated and they are not easy to sharpen along each and every gullet. This Razor Sharp thing does serrated knives fast, well and easy so I'm good with it.
I knew about strops and never really paid much attention to them before but they definitely got my attention now! I suspect a few seconds on a strop will deal with her requests from now on, Mike.
darkzero
Global Moderator
Staff member
Nov 27, 2012
6,427
Stropping is great. Many times if the edge is not chipped/damaged & is just going dull, there's no need to resharpen it, stropping will usually refreshen the edge. I strop with leather followed by balsa wood with diamond paste on my Wicked Edge. Besides the common leather strops, denim jeans loaded with compound makes for a good inexpensive strop also.
Here's a blade that I just sharpened for my lil brother last week. He bought it used, edge was badly chipped, it was so dull it wouldn't even cut warm butter! :D
Got the chips out, went through the grits all the way up to 2000 grit @ 18° (per side), then stropped from 14μm to 3.5μm. It was hair popping sharp with a mirror edge when I was done with it.
20190821_213626-800x450.jpg 20190821_213022-800x450.jpg 20190821_204135-800x450.jpg
mikey
Global Moderator
Staff member
Dec 20, 2012
7,297
Very nice, Will. I read about the different mediums guys were using and it seems that you can go through a lot of options in search of the ultimate edge. Maybe when I have more time I can experiment more. When I do, I'll ask you first.
darkzero
Global Moderator
Staff member
Nov 27, 2012
6,427
Thanks Mike. Yeah knife guys are crazy, they always looking for the next best medium out there to get the most extreme edges they can. I'm not one of those guys, all that stuff can get pretty expensive.
I just use diamond up to 1000. Then use 1500 & 2000 grit sandpaper mounted on blank blocks. Leather & balsa for stropping. It works for me so I just stick with that. I tried ceramic stones but was not impressed with the ones I bought.
If I were to just buy or make a hand strop I'd just stick with leather or denim & use your favorite rouge. As you know, don't even need a mirror polished edge to have a razor sharp blade. I only do it cause that's the result I get with my strops. It depends on what you use the knife for. Some people don't sharpen their blades past 600. The fine "scratches" act like mini serrations.
homebrewed
Jul 28, 2017
562
Yeah, I made myself an eternal "honey, can you touch this up" job too. But since I like to eat, that's OK!
In the absence of a real strop, I've found that ordinary newspaper can serve as a temporary substitute. There appears to be enough siica in it to act as a mild abrasive.
As a kid, I sharpened my pocket knives freehand and learned to feel when the edge started to catch on the stone. Got a few to the shaving stage, but that in general was an aspirational goal (what beard!???).
This is a great thread, thanks to everyone for all the different approaches! I think it just goes to show that technique is 90% and the tool is what's left.
jcp
Nov 29, 2017
184
Well Mikey, you convinced me.......ordered a Razor Sharp yesterday.
mikey
Global Moderator
Staff member
Dec 20, 2012
7,297
Let us know how it works for you. I'm pretty sure you'll like it.
May I suggest you also make or buy a strop? You can get the leather pieces already cut on Amazon and they aren't too expensive. They even sell kits that come with some polishing compound, usually green. I've come to view the strop as the final step when sharpening a knife. It really makes a difference.
jcp
Nov 29, 2017
184
Dad always finished with a strop.
I'll check out your suggestions....thanks.
ACHiPo
Feb 2, 2017
908
I bought a Razor Sharp (from the inventor I think) at a woodworking show probably 20 years ago. It worked great. It definitely taught me the value of stropping. I wish I still had it (May have to pick up another grinder and Razor Sharp set, but I’ve been working on my manual technique with stones). I ran it on my 1750 RPM 8” grinder so I could keep the guards on.
jcp
Nov 29, 2017
184
You were right Mikey.....the strop showed up today and I tried it out on 4 of the kitchen knives. They ARE "scary" sharp. Thanks for the info.
AdBlock Detected
I've Disabled AdBlock
