- Mar 26, 2018
- 2,724
Hi All,
Somehow after 5 years of working with reamers, I still am missing a lot of knowledge. I'm hoping that someone can share some tips with me!
-Mike
- My reamers tend to leave a bell mouthed hole when using them on the lathe. I hold them in a quality keyless chuck. I know my tailstock is slightly out of alignment but not by much. How close does the reamer need to be to true on center to cut correctly? My drill chuck has .003" TIR, is this even too much?
- My reamers often squeal and leave faceted chatter marks when entering a hole right at the edge. How do I prevent this?
- I was taught low speed and high feed for reamers. Can we be specific on SFM and feed per tooth?
- Sometimes my reamers will bind in the hole as they get deeper. They're brand new and sharp, so I'm wondering if the grind geometry could be wrong?
- Are reamers used only for hole size and not straightness? I am used to boring almost all my precision holes.
- From another post of mine, it seems like the long shank of the tool is important to allow it to flex and center. Is this a requirement?
- What percentage of the final hole diameter should the pre-drill be? Should the hole be bored before reaming?
- Are my Shars import brand over-under reamers the source of my issues?
-Mike
