[4]
Rebated 450 Marlin brass
[3]
[10] Like what you see?
Jay-z
Jun 12, 2014
116
My plan is to shoot 450 Marlin out of a standard AR 10 platform using rebated magnum brass. I could just change the bolt to a magnum face, but there isn’t any fun in that. I like to stick to the more commonly available items . So I started rebating the rims on some magnum brass using a lathe. This process works but it is very time consuming. What I am looking for is alternative method to rebate these rims or some ideas of a possible forming tool to do this type of work without the use of a lathe. Simpler the better . Any thoughts..........
Jay
Silverbullet
Gold
May 4, 2015
3,420
You could machine a tool with the base diameter and add a cutter in the side or end , with a spring loaded center it'll turn on center with a drill to power it any case length cutter does the same on the opposite end . Holding the case when cutting can be done with a board , bore holes to case size , like five holes saw board in half through the holes and you have a clamp for bench or vise. Hope this may help
Jay-z
Jun 12, 2014
116
So what is your process of rebating?
I simply chuck them up in the lathe and have several forming tools that I rebate the rims with. First I turn it to diameter needed, and then I add the extractor groove. Very simple, easy, but time-consuming.
derf
Brass
Oct 3, 2015
722
I've done several in the past by using a form ground tool that does the extractor groove and the rim diameter at the same time. I put a stop on the cross feed, and it's just a straight plunge cut.
I chucked up a die with the guts removed, then used a cleaning rod to knock them out.
I turned 50 BR cases down to PPC rims in about an hour.
Jay-z
Jun 12, 2014
116
I feel it doesn’t get much simpler than that for people who own a lathe.
MarkDavis
Active Member
Feb 9, 2018
73
Fun project.
I took the easy route, purchased a 45 raptor barrel, now channeled to .452 diameter bullets, and modified .308 brass.
Have lots to do just getting the rifle to operate. The "blemished" upper purchased so "cheap" seems to have a centerline about .030 closer to the takedown pin holes than the .308 upper that functions on my lower.
Working on problems including bolt carrier group rubbing on hammer, bolt hold back, and magazine.
I can report that it strikes the 100 yard gong with authority.
wrmiller
Chief Tinkerer
Mar 21, 2013
3,440
Fun project.
I looked at the 45 raptor as a potential 'large bore' conversion for my Juggernaut AR-10. Where did you get the barrel?
rwm
Mar 25, 2013
1,520
How about some pics guys? What exactly does the term Rebating mean in this context?
Robert
MarkDavis
Active Member
Feb 9, 2018
73
If I was planning to shoot .450marlin in an AR-!0, then I would turn the rim down to match a .308
Now just a little bit more thread hijack, these 45 raptor cartridges are not yet fireformed, hence the bulgy appearance.
Loaded with Cheycast high tec coated 250 grainers
ESSMH
Newbie
Oct 5, 2018
2
I built and have been running a 45 raptor for a while now, using 460 S&W data and the more reasonably priced .452 bullets make it a dream! My next "project" is to send my $60 XVR Revolver Cylinder to TK Customs in IL and have them cut my cylinder for moon clips, Then I can shoot 45ACP, 45 Auto Rim, 45 Sch, 45LC, 454 Cas, 460 S&W, AND 45 Raptor out of it! I did a bunch of research and really love the caliber and now Graf and Son carries the Starline Brass for about a buck a round so much easier than turning my own.
dpb
Oct 8, 2016
112
Robert
I don’t have any pictures, but in the simplest terms, rebating in this case refers to turning down the rim, or bottom most portion of a cartridge case to a smaller diameter, in order for it to function in a rifle, or action type that would not otherwise work. The extraction groove immediately in front of the rim generally needs to be turned down, as well.
john.k
Active Member
Nov 4, 2018
128
If you do cut into a case base,I suggest you might section the first one to see how much brass is left .......dont want to be a wet blanket,but there have been some notable fails doing this.
Jay-z
Jun 12, 2014
116
Not worried about the hijack. I love 45 Raptor, have several. How about some fire formed 45 Raptor brass made in a modified 30-06 barrel. I have a Raptor reamer.287418
[6]
[5] [7]
