- Nov 19, 2011
- 966
mix and match in the older vehicles is not bad you just have the basics to deal with, take ford trucks for instance motor mounts and stands, each engine has its own, smaller the engine the farther back it sits the bigger the engine more centered it is, the transmissions cross member has holes so it can move forward and backward depending on engine and transmission size, steering from manual to power you just have to know what yrs will interchange for the 68f100 is 70 to 74, the i beam interchange is 78 79 for disc brakes, c4 is a small block tranny from a 289 or 302 of course or a 351 windsor will interchange now here comes the tricky part flywheels torque converters must match the tranny:biggrin:Mac
