I chuckle when I read through this post, and it got to one and a half pages before someone mentioned dies (taps may be needed to). When doing tapered pipe threads without a tap/die, there is a lot of set up on many lathes... the changing of lead screw gears is trivial when compared to setting up the right taper for the Internal Diameter tapered cut (unless you want your threading tool to do the heavy cutting while creating threads). This is why commercial locations use taps and dies to do tapered pipe threads (or CNC). They produce consistent results which are easy to master, with virtually no set up, other than to change the die (or cutting teeth in the die head). If I were going to be consistently cutting ten different tapered threads, a tap and die set, or a tap and die head with replaceable cutting thread inserts would be my method of choice. This method can even be done on a turret lathe (which will normally NOT have a compound feed for tapers, in a non-CNC production environment). Cutting an internal diameter to a taper is easy, the setup cutting a tapered thread is more complex.
On this website, take a peek in the "a beginner's forum", they have a sticky posting on cutting threads. You will note there is almost no mention of tapered pipe threads, as it is not considered a beginner's technique, without a tap and die.
