Recommendation on collets.
Tienle
Feb 23, 2018
20
I need to get a set of collet about size 20 and up for my 8mm Boley lathe. What are your recommendations for them. Are they standard and interchangeable between maker or I will need specifically the one for Boley?Thanks
brino
Confirmed Tool User
H-M Lifetime Diamond Member
Jan 2, 2014
5,148
Hello @Tienle,
First, Welcome to the Hobby-Machinist!
Second, I am not sure what you mean by "size 20". Is that 20mm, ER-20 or something else?
Actually, I'm not sure what you meant by "8mm Boley lathe" either. Typically lathe sizes are given as "biggest diameter you can swing over the ways" x biggest length between centres". Like a Southbend 9"x36", could theoretically turn a workpiece of 9 inch diameter by 36 inches long.
Does your Boley lathe have a 8mm threaded spindle?
Does it have a tapered hole thru the spindle?
The more info you can give the more help we can provide.
For some background on lathe collets have a look around here.
These threads show a number of collet types:
https://www.hobby-machinist.com/threads/is-there-a-definitive-article-on-collets.36227/
https://www.hobby-machinist.com/threads/need-advice-about-lathe-collets.59971/#post-494287
https://www.hobby-machinist.com/threads/collet-sizes.38362/#post-328701
If you're unsure what I mean, please post back.
We will figure this out and give you all the help we can.
-brino
brino
Confirmed Tool User
Jan 2, 2014
5,148
I thought 8mm or 6mm are common term for watchmaker lathe.
Maybe it is just me unfamiliar with those terms.
Is it one of the models I linked to on lathes.co.uk?
Can you provide any pictures?
-brino
VSAncona
Dec 22, 2011
298
I have an 8mm Derbyshire, WW-pattern lathe and in my experience, it's a bit of a crap shoot as to whether collets from other makers fit or not. The length of the collet, the size of the keyway, and the thread pitch and tolerances of the threads all factor into whether or not they will fit. Some collets from other makers fit just fine and others don't. Conversely, I have one of those little after-market accessories to hold a collet in the tailstock and none of my genuine Derbyshire collets fit it, but collets from other makers usually do. Do your Levin collets fit your Boley lathe?
Tienle
Feb 23, 2018
20
I didn’t have any collet for the levin yet but I just bough 12 assorted collets. Only 3 fit to the non-Levin drawbar. Now I know for sure they are different.
brino
Confirmed Tool User
Jan 2, 2014
5,148
Hi @Tienle ,
I guess the name "Boley" must have stuck in my head from this thread. I just happened to notice today that same name on a block of collets at my local used tool store. See photos below.
I have no idea if those are good prices or not...but our Canadian dollar is lower than your dollar.
If you're interested let me know either thru this thread or a private message by hitting "start conversation" on my members page. I will be back to that store on the weekend and could buy what you want and ship them along to you. I don't want to make any money off it, just pay my costs (parts plus shipping).
I would need to know:
1) how to tell the Boley from the Levin/Derbyshire/other collets,
2) what size collets you are after, and
3) what condition you want.
-brino
Tienle
Feb 23, 2018
20
Hi Brino,
I really appreciate your offer to help. For now I have to sort out what I have and what I need. I guess the problem may come from the incorrect drawbar. I just bought a precision chuck with 8mm spindle. It works for me now. I will figure out what collets I need later. Thanks again for your offer to help.
chips&more
Mar 19, 2014
2,648
Can’t say I have come across all the various brands of 8mm collets. But from what I have seen the length seems to the big difference. And that is easily corrected with a thick washer/spacer kinda thing. Please note the front angle reference is one part of alignment and the other is the collets back shaft diameter. If that marriage in the back is loose, the collet can be cocked, causing a solid angle discrepancy. Could be for a problem or maybe not. IMHO, that is the big difference/concern when you have an assortment of 8mm name brand wire collets in a set. Hope this helps…Dave
Illinoyance
H-M Supporter - Silver Member
May 4, 2019
256
8mm collets come in two different lengths and two different threads. I bought a drawbar from a Chinese vendor. It has Imperial threads on one end and metric on the other. The position of the collar is adjustable. I can use any 8mm collet on my lathe.
For Brino: The size of a collet can refer to the body diameter, 8mm or 6mm, etc. Or it can refer to the size of work it holds, measures in 1/10 mm. A size 20 collet will hold 2mm. stock.
AdBlock Detected
I've Disabled AdBlock
