[4]
Relieved a VW camshaft
[3]
[10] Like what you see?
n3480h
Dec 22, 2012
328
Likes
136
#1
About to assemble a stroker 2287cc VW engine for my Sonerai experimental aircraft and found that the piston rod caps don't quite clear the camshaft. I chucked the cam in my HF 7x14 lathe and ran a live center in the tailstock to keep the cam straight. Holy cow forged cast iron is hard, lol. Got some hot chips while finding the right feed and speed, but the little lathe won the fight. I now have .070" clearance between the rod caps and the cam, and I can begin assembly of the engine. I am amazed that such a small lathe can cut such hard material, but it did well.
Tom
jerryhawthorne
Aug 13, 2012
28
Likes
0
#2
Tom, is your engine an air cooled perhaps 1600 cc to start? Be safe, particularly in an aircraft! Seems a large increase in displacement. VW engines were notorious for pulling head bolts out of the crank case when pushed hard. Nice job on the con rods.
Jerry
n3480h
Dec 22, 2012
328
Likes
136
#3
Thanks for the compliment, Jerry. This engine was never automotive, nor has it ever been 1600cc. It is an aircraft conversion engine built from the ground up with a special case, a huge bearing and taper fit prop hub on the business end, an 86mm E4340 steel crank, forged and nitrided. Dual plugs at each cylinder with a magneto and a Dyna 5 electronic ignition for redundancy. 2400cc aero converted engines are fairly common these days. Mine is a 2287cc, with 92mm jugs, an 86mm stroker crank, and lightweight Arp racing rods. The engine will produce 85hp at takeoff, 78 sustained, with a compression ratio of 7.8:1.
30-40 years ago, many used the old 1600cc Type 1 VW Bug engine without modification. Stock cast cranks, single distributor ignition, and untrustworthy fuel systems. A few had problems, and by the time word got around . . . a handful of incidents became "ALL VW engines in aircraft are death traps". This is not the case today. Modern aero conversion VW Type 1 engines often go 1500 hours before a bottom end overhaul is required. Keep the oil clean, use the right oil, set the valves every 25 hours, don't overtorque cylinder studs, and pay attention to general maintenance and inspection. That's all it takes. Reliability is now very similar to certified aircraft engines, (better than some) and fuel burn is considerably less. A few are even turbocharged or EFI. They've come a long way.
Tom
[6]
[5] [7]
