Sharp eye!
It could be... I’ll have to take a look with my loopers tonight.....
Brad
Sharp eye!
Nope ... just crud/camera phone noise...
There was something similar around 10 o'clock. Give it a loop look, too.
That is basically what you are looking for - a small access hole that lets you manipulate the catch spring. If you can't find one, sometimes you can remove the bezel by pulling up while you twist the bezel. As you twist and pull, the spring slowly gets moved into the bezel groove.
