[4]
Removing paper from old Plexiglas!
[3]
[10] Like what you see?
KMoffett
Jan 18, 2013
419
OK, I've read every post on how to remove the paper from old Plexiglas, after the glued has dried out. None of them worked, or take more effort than the scrap is worth. Yesterday I had a student that works in our Chemistry Stock Room take piece of old Plexiglas (>10 years old) and handed me back a clean sheet. She said they use 3M Citrus Based Adhesive Remover to get the years old labels off chemical storage bottles. Sprayed some on, wait a few minutes, used beveled Plexiglas scraper to start lifting the paper, and it pealed the paper in sheets. OK, edges where the paper had lifted over time, and the glue had turned rock solid wasn't touched. Contains: citris extract (8028-48-6) and propane (74-98-6). Sorry for those of you on the West coast.
Ken
4ssss
Brass
Apr 25, 2017
603
Good tip. I tried Goo Gone, and that only works marginally with allot of effort
mmcmdl
H-M Supporter - Gold Member
Staff member
Jan 31, 2016
1,506
Thanks Ken , I'll give the stuff a try . :encourage:
aliva
Feb 28, 2012
371
that's a great way to do it. I've always struggled with that dammed paper
KMoffett
Jan 18, 2013
419
Heat on dried paper glue has never worked for me. Neither has kerosene. Nor have many many other solvents. Some will dissolve the paper, but the dried glue stays.
Ken
Franko
Feb 24, 2015
1,345
I've had fair luck with mineral spirits paint thinner. I soak it for a while (30-90 minutes) and it peels off fairly well but leaves a film of gooey. Then I have to struggle to get the gooey off with a plastic putty knife, more thinner, and lots of paper towels.
Diecutter
Dec 19, 2018
65
This is why the sign companies dump all their old stock onto ebay at bargain prices. It's a good deal if you are a hobbiest like me with time to remove the backing.
KMoffett
Jan 18, 2013
419
Steel ink Remover MSDS
Contains Acetone...not good on Plexiglas!
Ken
Latinrascalrg1
Active Member
Dec 9, 2016
439
When removing old wallpaper there is a tool that is used to gently score the paper creating a bunch of holes just in the paper to allow the solvent to saturate the paper and glue so that it will help with the removal but will still take a bit of patience....Hot steam really expedites the process. Now ive only used the process on the stubborn plexiglass paper issue only one time but it worked given half the chance.
[6]
[5] [7]
