[4]
Repairing destroyed vise
  • Thread starter Deleted member 43972
  • Start date
[3]
[10] Like what you see?
D
Guest - Please Register!
Is there any hope for this vise?
I have a new chinese vise coming. But this one is bigger and actually better, but it's been chewwwwed up. I could use the new vise to make new jaws, but is there any hope of point in repairing the bottom to bring back some accuracy when I use parallels?
David S
Nov 18, 2012
1,327
At first I thought that this should be in the "joke of the day" forum. That thing sure has seen better days.
However...just however, I bet someone here will have a suggestion for restoration. Is it a name brand? Surely not a Kurt??
David
D
JB weld? What are these other epoxies?
I don't remember the brand. I'll check when I'm home.
Dave Paine
Brass
May 10, 2014
813
JB Weld is a brand of epoxies sold in at least the US, many different products under this brand. I have had good results with JB Weld. The original formula takes a long time to cure, but hard once it cures and supposed to be good for over 500 deg F.
D
I just found JB weld at home Depot. Awesome. Bought two packages.
That was easy for once!
I have a project in the vise right now. Once I'm done I'll have to do a major degrease.
Alittlerusty
Active Member
May 16, 2015
155
My experience with the jb weld is it shrinks quite abit when dry. It may take a couple tries to get those holes filled all the way
markba633csi
Gold
Apr 30, 2015
3,587
Use a source of heat with JB weld to cure it, a light bulb (do they still make them?) works well. You want the temp at about 100 degrees F for about 4 hours to get it nice and hard. Add some steel filings for even harder fill, like those big dimples in your vise. I'm a happy JB welder LOL
Mark S.
Dave Paine
Brass
May 10, 2014
813
I mix the JB Weld on a piece of masking tape. I have not needed to mix large volumes. I put the masking tape with the residue aside so I can test it cured later. If the residue cured, I feel confident all the epoxy in the fix should be cured.
For holes on the side or through holes, cover the side/bottom with masking tape. The JB Weld will flow for a long time - slowly but enough to mostly drain a through hole if not blocked at the bottom. Same for the side.
D
I've done huge epoxy pours on live edge wood bar tops. I hate epoxy. Lol. But it does look great and is very workable when hard. I'll see how this stuff goes once the big block of aluminum comes out of the vise.
D
Yeah. This live edge had knot holes going straight through. Those dark spots in the bottom of the picture. Went straight through. had to mask and block with plywood and epoxy still came out. Had to do it in three pours.
D
I had pondered welding, but I don't want to risk warping it due to heat.
Silverbullet
Gold
May 4, 2015
3,450
I think if take your time and do center tig braze outwards in small areas over several hours . Being cast I figure the bronze should flow in and fill without distortion . Done slow it'll be there to stay. After each heating I suggest keeping it warm for a few hours to overnight .
I don't know if jbweld Will hold up with cutting fluids . I did a repair on an cast iron block kohler engine the owner said use it to fill a crack inside and out. After it cured for 24 hours I rebuilt the engine . Needless to say it ran a few days and came back leaking and blown.
There are other metal filled epoxy devcon. Has some really good ones do your homework and do what you thinks right.
D
What about oxy acet brazing? That's all I have aside from the multiprocess welder. (no Tig)
RWL
Nov 11, 2011
222
"What about oxy acet brazing? That's all I have aside from the multiprocess welder. (no Tig)"
Oxyacetylene welding/brazing heats up relatively wide areas although admittedly brazing occurs at a lower temp. The advantage of Tig is that it's focused heat. I'm not sure whether Tig would or would not warp the cast iron which is why I posed the question of whether anyone has done a repair with Tig. I don't honestly know the answer. I was hoping to hear from someone who tried it. Filling holes with metal is a more durable repair, and probably more cosmetic.
RJSakowski
Feb 1, 2015
3,898
I worked with epoxy composites for six years with a good deal of time spent studying cure rates.
When an epoxy has hardened to the touch, it has only cured about 10%. A full cure can take years for epoxies that take a day to harden. Epoxies also continue to shrink with curing. Heat will hasten the cure with the cure rate doubling for every 10ºC increase in temperature. A higher temperature will also result in a harder and more heat resistant product. Epoxy also has a property called the glass transition point which is the temperature at which the cured epoxy changes from a rigid to a plastic solid. This temperature increases as the cure becomes more complete
If I were repairing the vise with an epoxy composite, I would fill the recesses generously and allow to cure at room temperature until hard. Then I would slowly increase the temperature until it reached between 110ºC and 130ºC. This process would take place over several days and the epoxy should be close to fully cured.
As to the composite, I would use a slow curing epoxy and mix in iron powder to make a thick paste. Not having the powder, saw dust from cutting iron with my horizontal band saw or filings from filing with a fine tooth file would work.
Fully cured epoxy is fairly immune to most solvents. I would expect good resistance to the chemicals that would be used in machining.
Billh50
Jan 26, 2015
1,922
The vise I repaired with JB weld has held up fine for the past 4yrs. And is still going strong. I did let it harden for almost a week to make sure it was hard all the way through.. This vise was my main vise for milling.
MozamPete
Jun 26, 2014
590
In South Africa we have a product called Pratley Putty which is a two part epoxy putty - you kneed parts A and B together and it softens as you work it, but then cures rock hard and can be filed or machined. I have used it on my mill table to fill the worst scares, and it avoids the problems with liquid type epoxy running out of where you actually want them to be.
It's a bit of a South African legend it was used by NASA in 1960's on Ranger landing craft, so has the distinction of being the only South Africa product ever to go to the moon.
RJSakowski
Feb 1, 2015
3,898
Epoxies seem to share some characteristics with concrete as far as curing
Exactly, and for much the same reason.
Concrete's curing depends upon water and carbon dioxide molecules finding their way to the uncombined calcium oxide to form hydrated calcium carbonate. Once the mixture solidifies, the only mechanism for this reaction to occur is for previously combined molecules to uncombine, passing the CO2 and H2O along and recombining with fresh CO2 and H2O, in effect passing the molecules along like a bucket brigade. This process will continue as long as there are uncombined sites but will necessarily slow down as the number of uncombined sites is available.
The University of Wisconsin began a study of concrete over a hundred years ago. Every year, a sample was removed and tested for compressive strength. The study was to have ended after fifty years but their testing showed that the samples were still increasing in strength so they elected to carry the study for another fifty years. As I recall, the strength continued to increase throughout that part with the study ended because they ran out of samples.
The epoxy reactants are an epoxide and an amine. The amine has multiple reaction site on each molecule which permits the cross linking that gives epoxy its rigidity. Like concrete, in a liquid form the molecules are free to move around to find active sites but once solidified, the bucket brigade mechanism is the process by which unreacted molecules find partners. And like concrete, as fewer and fewer active sites are available, the curing rate becomes slower and slower.
Fortunately, with both concrete and epoxy, the products reach an acceptable state of usability long before the reaction is complete. In my particular case with the epoxy composite, we were trying to make a product with extremely tight density tolerances so curing shrinkage was of great concern. I would think that shrinkage, hardness, and possibly temperature resistance would be issues of concern when trying to build a precision surface such as the floor of a milling vise. To that end, I would error in the direction of overcuring rather than under-curing.
rgray
Nov 26, 2012
1,141
I had a canadian customer that brought me a product called Metalset A4 made by the company Smooth-On.
It was so much better than JB weld it was unbelievable.
I found the website. smooth-on.com
It says to store and use it at room temp...funny he told me to keep it in the fridge.. It also says it has a limited shelf life....maybe that's why the fridge...have had these two tubes for 20 years and everytime I use some it works great.
Dave Paine
Brass
May 10, 2014
813
Interesting. Smooth-On moved for Easton, PA west so now about 40 min drive. I have been to the new location a few times to purchase other epoxies for wood working.
The Metalset A4 product is not cheap, $20 for 11oz. I may have to pick up the 11oz size to give this a try next time I visit the store.
[6]
[5] [7]
