Replacement handwheel for Husky mill
larry2c
Jun 14, 2014
28
I have a Husky knee mill (clone of Grizzly 8X30) and only one of the cheezy plastic handwheels is not broken. I bought a 6" chrome plated cast iron handwheel and it came with a 1/4" hole in the center of the hub. I have bored the hub out to 1.305 and the old steel hub that I pulled out of the OEM plastic HW is 1.312 OD and it is a knurled OD. I plan on pressing the old hub into the new HW and I think with the hub being knurled the .007 press fit will be OK. However, I was thinking of also putting some Loctite or maybe some other type of adhesive on the knurled surface before assembly.
Just curious if others have done this repair and if so, did you use anything besides just a press fit. Attached pics show the HW and the OEM hub.
A .007" press sounds scary to me. It would be a shame to split the hub (now fairly thin walled) on your nice new hand wheel.
Why not turn down the old hub to a .001 press fit? Add loctite or epoxy just because?
"Why not turn down the old hub to a .001 press fit? " I'd love to, but no lathe - yet :grin:. Normally I would go with about .001 to .0015 on the press but since the hub I'm going to be pressing is knurled, I think I need more - anticipating the knurl points to actually cut into the softer cast iron.
I quite agree on the fit being way too tight; I see that the tops of the knurls are truncated, so the fit with 1 or 1.5 thou would be plenty. It's not like there is a lot of torque being transmitted with that handwheel.
OK, I can bore out the HW to get the .0015 press. What Loctite or other adhesive would you recommend?
I would not use loctite, I'd use a anti seize (white lead is my favorite), assemble it, and if you are concerned with movement or slippage, I'd drill and tap it axially at the interface of the two parts and screw in a long setscrew.
John, I've used zinc (silver) and copper (bronze) anti-seize paste, but I've never seen white lead- where do you get it, and what application is it found in?
White lead is no longer on the market, but I have had success finding it on e bay. It is the very best anti seize for press fits and interference fit threads. If you get some, pour off the oil that is floating on top and replace it with machine oil, the original oil is linseed and it hardens if exposed to air. White lead was formerly used in paints, and supposedly caused intelligence problems with inner city kids who ate paint chips or chewed on window sills.
If you can't find any and want some, I could help out, got lots of it.
Lead seems like the ideal anti-seize. Looks like lead carbonate was mixed with linseed oil and was good at doing a number of things. I like shopping for old cans of pesticides and poisons on eBay for office art, looks like I can add this one to my search!
I LIKE your attitude!
