I posted a picture of the switch in attachments but ill link it again.yes the numbered wires run to the motor the others to the switch. thanks for help.I think, to get a true idea we need to see the other end at the reversing switch. I suspect there may be a wiring error but without seeing the switch I can't say for sure. To reverse the motor the factory is either swapping the red/yellow or the black/white
-Mark
The concern about the two bottom posts is unfounded- the posts are merely mounting points- the wire #s and colors match and that is all that matters.
So the motor is wired for 220/240. I believe the little breaker and incoming black wire are not used for 220/240 volt case and should be removed.
