- May 10, 2012
- 991
I don't know. I'll do the math before I fire it up to see what rpm this should run at.
While I'm on the subject??
You shaper guys know the best rpm to run on this type of machine tool?
Appreciate it.
The calculation for the surface speed and a table for recommended speeds is in Moltrecht's Machine Tool Handbook. It depends on the stroke and material, the longer the stroke, the higher the surface speed for a given RPM. I would recommend a range from about 50 to 150 or so for that size machine. The higher SPM for very short stroke cuts, otherwise it will want to walk across the floor.
