- Jan 14, 2013
- 62
I got my delta rockwell lathe running. The only issue i have is the belts for the vari drive are very loose and there is no adjustment. Are they supposed to be loose? These are not the spring loaded vari belt pulleys. They are a solid vari pulleys. Can anyone get me the correct size of these belts or the correct part number? I dont know if the wrong belt is on it or what? I can stop the chuck with my hands. The belts are 1-1/2" wide. Are these belts supposed to be loose? I never had a vari drive anythig before so I dont know. The lathe is a rockwell delta 14" x 40" all the 14" rockwell lathes used the same vari drive belt system. Thank you, Jason
