Rong Fu 45 head stop
Howardd
Mar 15, 2016
39
Is there a stop that prevents running the head so high that the rack disengages from the worm gear?
Thanks
Howard
I have a similar machine. On it anyways, the rack is held on by a cap that would disallow running the head up off the column. You could though, if you wanted, remove that cap, and take the head off the column. It’s threaded on.
I misremembered. The rack runs out of teeth. It can’t run off the top because that.
