Started on this project today. First I needed some T nuts for mounting. Ended up with 7 of them out of this bar of 4142 material
Trueing them up after the other end was squared up.
Drilled and tapped 1/2-13 thread
Now I need to make a chuck wrench.
Now I am able to clamp the chuck down to drill the mounting holes through it. First I had to get this beast of a table on the mill.
The chuck is sitting on blocks for drill clearance. Notice the layout marks I used to align things up. I only had 3 small areas to get these holesin in.
All clamped ready to indicate and drill holes. Notice the bar in the chuck. This is turned to nice slip fit of the center hole of the table. I put this in the table and then tightened the chuck and it centered itself.
After the chuck was clamped I extended the bar above the jaws to indicate center.
Holes are drilled and counterbored for 3/8-16 S.H.C.S
That was all for today. Tomorrow I will drill and tap the mounting plate to bolt the chuck to.
Good job so far. Thats one big boy rotary table! I like the radius end mill touch on the chuck key. I chamfered an angle in that section on the lathe when making my key.
Made a little more progress on the plate. 3/8-16 holes are in that hold the chuck to the plate.
I ran out of room in the z axis for the 4 holes that mount the plate to the rotary table. While it was in the chuck I center drilled the holes so I could locate them in the next operation.
This may not be a ground breaking way to do things but this tool works well to get location of the holes then the part is clamped down.
This is what I did to locate center of the table. I have another 2" dia pin with a slip fit to the table center hole that sits just below the surface. I used the same ream as the other 4 holes (.5005) to put a hole in the center of this pin to locate with.
Verify center of table.
Next step is to make the plate with the offsets so I can mill the pockets for the clamping nuts.
Next I located the mounting plate for the milling operation. This is why I reamed the holes so I could locate them accurately. The pin in the picture is a slip fit in the mounting plate and is centered in the center drilled hole. On this pin the part pivots to a location I have layed out that the o.d. of the mounting plate stops at.
