- Nov 18, 2013
- 86
Yeah i know it's been asked a thousand or so times before and it has nothing to do with speeds and feeds the problem exists through all spindle bearings seem to be good a meter of bar stock pulled or pushed shows next to nothing on the DTI the saddle keys are adjusted and so is the compound and cross slides worked on other lathes with a lot more wear and nowhere near the same problem The main issue is it will take a deeper cut for a revolution or two as if the tool is being dragged into the work it much worse with the kyocera tungsten tips changing inserts no change it will cut better with tool steel but the problem is still there the only thing is the cross slide has a little backlash but this has been normal in most lathes that i've used any thoughts on what to look for next
