Rubber foot for 820 peg leg?
HarryJM
Mar 16, 2015
384
Has anyone found a piece of rubber that will work for the rubber foot support for a Logan lathe (any model that has a peg leg)?
I believe they used to be sold on e-bay also. If I recall, the material was pretty stiff.
You could probably get away with trimming a hockey puck to the cavity diameter of the leg post and follow with a counter bore to capture the small adjustable metal foot. A plain old wood spade bit on a drill press works OK for cutting the counter bore in hockey pucks. It sure does stink when you cut it though.
TomKro
If you get a crutch tip for it get black rubber NOT white...
I've got both tips on push sticks and the white(s) has not lasted as well as the black.
I like the hockey puck idea, keep forgetting that. . .
I also like the hockey puck suggestion although this morning I just remember that I have a left over piece of rubber flex pipe connector (Fernco 1-1/2-in x 1-1/2-in x 1.94-in dia Coupling PVC Fitting) that I will try and fabricate a rubber cup from. Its plenty thick enough and I should be able to cut and glue up a cup with the left over piece that I have.
