[4]
Ruger M77 Tang Safety-make a pin
[3]
[10] Like what you see?
Gfrost
Active Member
Feb 11, 2016
43
Likes
15
#1
I picked up an old Ruger M77 tang safety model. It was in rough shape the finish anyway!
I broke down the action in order to refinish the action and than later rebarrel to a different chambering.
Well in doing so I attempted to punch out the ejector plunger pin which was not coming easily, I ended up drilling it out.
Ruger tells me that those pins are no longer available!
So, I thought that I would just make one. Question is what should it be made out of, Drill stock? Or?
Gary
BtoVin83
Active Member
Aug 30, 2017
190
Likes
182
#2
I have made a lot of pins out of the straight portion of a drill, they're are not hard hard but pretty tough
rgray
Nov 26, 2012
1,062
Likes
558
#3
I usually use gauge pins. If you have a set you can find what size is needed and sacrifice it and order a new one, or order the extra to use as your pin.
sometimes the fit is not quite right....say for example you have a minus set of gauge pins and the best fit is slightly loose, then order a plus pin in that diameter to use as your sacrificial pin.
Gfrost
Active Member
Feb 11, 2016
43
Likes
15
#4
Perfect, thanks guys!! Broken drill bit was the first thing that came to mind but wasn't sure if they might be to hard for that application?
I will give a drill bit a shot! Thanks again!!
Gary
derf
Brass
Oct 3, 2015
697
Likes
808
#5
I've made hundreds out of O1 drill rod...they work fine.
[6]
[5] [7]
