[4]
Running a big machine from a domestic supply
[3]
[10] Like what you see?
SamI
Active Member
May 31, 2018
111
Hi all,
I am hoping some one can offer some advice. It may have been asked before but I can't seem to find a simple answer!
I have the opportunity to buy an Ajax Cleveland No 2 mill which I am very tempted by if the price is right. The only thing I am not sure on (other than how to get a 2000 Kg machine into my garage) is how to power the thing.
I am led to believe that it has a 6 hp motor plus a 1.5 hp motor for the power feeds. I have a 240 volt single phase supply to the garage. A (very) quick google would appear that a VFD phase converter on a 240 v supply is only capable of powering a 3 hp motor. Would this mean that the motor won't run or that it would simply be under powered? Or am I missing something all together? Would I need two separate phase converters, one for the motor and one for the power feeds?
Thanks in advance for your help. I've been putting off looking into three phase for a while now due to fear of the unknown but this machine has the potential to be an offer too good to miss out on!
Sam
Richard King 2
Master Machine Tool Rebuilder & Instructor
H-M Supporter - Commercial Member
Feb 1, 2018
431
Back in the old days when shops were underpowered we would hit the start switch and shut it off and then start it again and again to get the motors coasting or speeding up slowly so all of the amps were not pulling from dead stop and blow a fuse. As the momentum was spinning up or RPM's were up there we would let it run.
Cobranut
H-M Supporter - Silver Member
Sep 26, 2018
8
VFD drives are available up to whatever power level you want.
We have them at work that can run 5000+ HP motors.
The only issue is cost, and the current capacity of your 240v single phase supply.
A 6 HP motor should draw around 4500 watts, so a 240v 20a circuit should handle it fine.
And yes, you'll want a separate VFD for each motor. A small one for the feed motor is dirt cheap
Motor leads should be connected directly to the VFD, and all the control done through the VFD's circuitry.
This allows you to program soft starts and stops, which minimize current spikes, and are also easier on gear-trains.
I installed 2 VFD's on my Rambaudi mill.
For the feed motor, I used the original drum switch to a remote input to start/stop the motor.
For the spindle, which I want to control speed via the VFD, I'm replacing the drum switch with a bracket for the VFD keypad, and will control it from there.
Cobranut
Sep 26, 2018
8
Also, you could probably run a 6hp motor on a 3hp VFD, but you'd have to program a very gradual startup, and of course, it would shut down on overload once you exceed approx. 3hp of load on the motor.
SamI
Active Member
May 31, 2018
111
Thank you both for your input. I guess the VFD programming is the more sophisticated version of Richard’s suggestion. Still trying to decide whether this will be a good buy or not. I suspect it is waaay to much machine for my current requirements and I am a little concerned about the max spindle speed of 1400 RPM – not sure how well that will play with small diameter cutters in softer materials such as aluminium.
Assuming the cost for a larger VFD wasn’t silly I’d probably choose to go down this route just to be on the safe side.
Thanks again for your help with this. Now I just have to wait and see how much they're wanting for it. It's an old toolroom machine from a company my employer has just taken over so I'm hoping the powers that be sympathise with my desire to fill my single garage with machinery top to bottom!
JimDawson
Global Moderator
Staff member
H-M Platinum Supporter ($50)
Feb 8, 2014
7,472
There are single phase input capable VFDs that will handle a 6 HP motor. A 10 HP VFD would do it. But given that you have several motors that require 3 phase, a rotary phase converter might make more sense.
My biggest concern is the low RPM of the spindle. It sounds like the machine is designed for some heavy duty milling with large cutters. 1400 RPM might be a bit light for small cutters in soft materials.
SamI
Active Member
May 31, 2018
111
That is good to know about the rotary phase converter.
I agree about the spindle speeds. I don’t do much work in aluminium but I probably care more about versatility than stock removal so it would be nice to have a larger range of spindle speeds. I have been told that there may be a Bridgeport going from our tool room and another mystery milling machine from another facility in the not so distant future so maybe I am better off holding out for that. I’ll still require a phase converter so this is all still really useful stuff!
ttabbal
Jun 12, 2017
798
One option is to set up the VFD to supply higher frequency at the top end. I do this with my grinder and mill and it works great. The motor on the Bridgeport looks original and it handles it fine. The grinder is a modern inverter rated motor. 2x speed should work fine for most anything.
I don't know about your area, but around here rotary converters are stupid expensive. I just use the ebay Chinese VFDs. I have 3 of them now and they work great. The Bridgeport has the old gearbox power feed, so it needed its own.
I'm a noob, but wouldn't slower spindle speed just mean it would take a bit longer? Perhaps not ideal, but for a hobby user it wouldn't be the end of the world.
pacifica
RGL
Jan 2, 2018
201
A vfd could allow you to overrate the motor by as much as 200% and also slow down to as low as 25 to 50%, that might take care of the spindle speed issue. If you have the room a big mill is very nice to have.With a modern DRO , rotary table ,spin indexer ,and dividing head there is a lot you can do.
benmychree
John York
Jun 7, 2013
2,867
There is nothing wrong with milling at lower speeds that production work may dictate, no need for high speeds for hobby work, and I'd just go with a rotary phase converter, for my shop, which has motors up to 7-1/2 HP, I made my own rotary, using a 5 hp motor and a static phase converter to start it, and added oil filled capacitors to balance to phases, it was cheap to make and works well enough.
Dabbler
Administrator Trainee
Staff member
Oct 11, 2016
728
At somewhere around 6HP, depending on your source, begins the transition where rotary phase converters begin to make sense. If you are bujying 2 VFD untis to power the machine, then a RPC is clearly a way to go - but -you lose the ability to control the speed directly or do overspeed. It easy hobby way is to VFD the main motor, ans use it wothout the power feed for a while, gaining the advantages of a VFD. THEN you can add a second VFD when you cna afford it, allowing the power feed.
A word of caution: It can be tricky to run two motors on one VFD. I would shy away from running your 6HP motor on anything less than a 6HP VFD. The impedance and the inductance are our of spec for the VFD, and can affect its operation. I'm not saying it can't be done, but it can be expensive if you damage your VFD.
markba633csi
Apr 30, 2015
3,174
Hi Sam: finding a VFD with single phase input/ three phase output with 6 HP (or higher) rating might be a challenge- do some online shopping first before you decide
mark
Dabbler
Staff member
Oct 11, 2016
728
-- Cobranut, I was referring to all US sourced equipment. A Westinghouse TECO VFD at 7.5 HP is about the same price as a Rotophase at a similar HP rating... at least it saves the cost of a second TECO.
I've never purchased any electronics from aliexpress, so I'm not the right guy to comment on that option.
SamI
Active Member
May 31, 2018
111
mark
I have seen a few available however all bar one is of Chinese origin from Ebay sellers. I’m not saying that they’re no good because of that but I do worry if they’re claiming that their units can do something that reputable brands cant.
Looking into it a rotary phase converter does seem to make sense and it looks as though these units are plug and play so there would be no fettling with the machine (a bit of a bonus for me as while I have the mechanical skills to be able to do this I am at a loss when it comes to electrical knowledge!). The down side to these is that they are quite expensive – likely to be more than I am hoping to pay for the machine.
As for the spindle speeds – some have mentioned that it’s OK to run a little slower. I’m not sure if the same applies with milling but I turn a lot of stainless on the lathe and BUE is a major problem for me if I’m not running the machine at a high enough speed. Inserts can fail to give acceptable finishes after only minutes of cutting. If I predominately used HSS cutters on the mill this would be less of a problem but presumably if I were using small diameter end mills then this could presumably lead to rapid tool breakage, or am I just making a mountain out of a molehill?
Cobranut
Sep 26, 2018
8
Thanks Dabbler,
If I were running these machines commercially, then I'd certainly look into higher quality electronics, but it's only for hobby use.
Both the 3HP VFD's I have work fine so far.
I'll be adding a third one on my lathe, so if one burns up in the middle of a project, I can always swap in another and order a replacement, considering they're under $100 each.
I don't particularly like purchasing stuff from China, but when the cost of US parts is multiples of the Chinese stuff, it's hard to justify.
For major stuff like vehicles, that I depend on every day, I do buy American, or at least from US based companies.
NortonDommi
Active Member
Nov 15, 2016
431
I am picking up some Transformers next week to rewind as auto-transformers to power some 3~ machinery. This is my first foray into this but I have read a bit about it in the Workshop Practice Series of books particularly #47'Three-Phase Conversion'. I have done the capacitor hook-up one 240 V 1~ but from what I have read doing it with 415 V works a lot better. I have also seen a book that I will purchase soon from Unique 3-Phase.com
https://unique3phase.com/ They have an interesting website. I'd love to be able to just go and buy a few VFDs but the budget is very tight.
TheArsonSmith, Nice video, you make it look so easy.
Blackjackjacques
Active Member
May 20, 2017
148
Hi all,
Sam
Long before VFD's, Reduced Voltage Motor Controllers (RV) were used to address the problems caused by motor inrush currents. They used either tapped inductors or resistors to permit the motor to start and minimize voltage dip and sag that would affect adjacent systems. They do make solid state RVs and that can also be used for speed control as well. Once the motor starts and is running, timed contactors close to put the motor across-the-line. If you are looking to minimize inrush currents, then you need a RV. If you are looking for speed control as well, then you need to make sure the motor is VFD rated. You should easily be able to start and run 6 hp single phase motor with 240 single phase using a RV appliance. The 1.5 hp motor you can start across the line. The primary stipulation you need to insure when selecting a RV device for your 6 hp motor is that you can meet the starting torque of the motor and the RV's reduced tap.
SamI
Active Member
May 31, 2018
111
Presumably this does a similar thing to programming a VFD for a soft start?
Thank you all for your suggestions. I think for now I'm going to hold out for one of the other machines that could be going in the near future - I think they may be a better match for my needs. Your help is still very much appreciated and there's a lot of useful information that I'll refer back to when I do end up getting a machine!
TheArsonSmith - I'm looking forwards to your video on the wiring and programming (it's probably out now - I should go and check!). There is a lot of conflicting information out there as to the best way of tackling this problem and it is reassuring to see that you have done it successfully!
GordonL
Newbie
Apr 15, 2016
2
I have been running my shop on a home made phase converter with relays and capacitors for years. I have never had any problem. In the home shop you are not too likely to use the HP capacity of the big industrial machines. Total investment for me was about $100. The biggest expense is finding a used idler motor. If you look around you can find big old ugly motors cheap. Hide the idler motor in the other room.
Apparently this forum will not let me post a link.
rcaffin
New Member
Dec 20, 2014
29
Have you thought of contacting your supply company and asking for an upgrade to 3-phase? Convince them you are going to need the power. They might prefer to go 3-phase rather than risk burning out one phase in their transformers. Seriously.
I did this, and got 3-phase at 60 A per phase. The biggest expense was probably their guy up the pole, but that was on their side of the connection.
Cheers
SamI
Active Member
May 31, 2018
111
Cheers
I had considered this however I am not planning on being in our current property long term. When we move in (hopefully) the near future then a large workshop and a 3 phase supply are high up on my list of priorities!
warrjon
Active Member
Jun 26, 2018
100
I run my 5hp 3ph mill from a VFD as I am limited to 20amps to the house a RPC was not an option. I do not take huge cuts in steel so have never drawn 20amps or I would trip out the load limiter. I have the VFD set to ramp the motor slowly to limit the inrush. My power feeds are 110V single phase so do not run from the VFD.
I would not recommend running motors of different HP and/or RPM off a single VFD as you will need to program the motor parameters into the VFD. If you can make an RPC cheap enough then this may be the way to go.
[6]
[5] [7]
