[4]
Rust
[3]
[10] Like what you see?
Martin W
H-M Supporter - Gold Member
Mar 26, 2014
360
Likes
320
#1
I had bought a bunch of taper shank drill bits a while ago. They were a little rusty so I soaked them in some rust remover. What a difference. Here is one 2-1/4” bit after 20 minutes
Cheers
Martin
markba633csi
Apr 30, 2015
2,768
Likes
1,434
#2
Holy cow that's a good size drill
M
vocatexas
May 8, 2017
110
Likes
116
#3
I've been using Evaporust on some tools I bought recently and I have been amazed at the results. That stuff really works!
D
Deleted member 43972
Guest - Please Register!
#4
Thank you for including your fingers for comparison...
TTD
Mar 28, 2014
123
Likes
208
#5
Holy cow is right...they’re only 3/4” smaller diameter than my lathe chuck! :D
dlane
Sep 27, 2014
2,927
Likes
1,373
#6
Holy stamped ,my dp would have a problem with that thing.
agfrvf
Mar 13, 2017
128
Likes
56
#7
I soak my cleaned and derusted parts in used synthetic engine oil. No rust on anything after treated and I live in heat and humidity central.
Ulma Doctor
Infinitely Curious
Feb 2, 2013
0
Likes
13
#8
Wow Martin, you must have a really big DP to run those drills!
Can we get a picture of the beast that can run those bits??? :drool:
Martin W
Mar 26, 2014
360
Likes
320
#9
What can I say, I like heavy equipment and it’s usually cheap.
The 2-1/4" and 2-3/4" bits have 5MT shanks. The only machine at the moment I can use them is my Lathe, which most times a boring bar is better. Most of the rest have MT#3 shanks which I can use in the Progress #3 drill press.
I am looking at a Radial arm drill that has a #6 MT but I am still trying to figure out how to get it home reasonably priced. It weighs more than the roll off truck can handle.
Cheers
Martin. 1B296F8E-42D0-41F8-B1D7-5FFF9BAE18A3.jpeg 0AD72038-3DE3-4162-8E2D-ADD9759C04D9.jpeg
projectnut
Apr 14, 2014
430
Likes
288
#10
Cheers
Martin
What brand rust remover are you using? I have tried several over the years and have not found one yet that does that good of a job. Every one I've used leaves a black coating where the rust has been removed.
agfrvf
Mar 13, 2017
128
Likes
56
#11
That is now preserved Iron(III) oxide. Same as bluing but much thicker in your case. It won't rust again
Martin W
Mar 26, 2014
360
Likes
320
#12
Project Nut, I’m using Evaporust. This is right out of the solution with no scrubbing. I just rinse with water and dip in again and let it air dry.
Cheers
Martin
[6]
[5] [7]
