Saved from the breaker: 40-2215H !
Chips'll Fly !
Feb 2, 2019
5
Hello everyone !
Delighted to have found this forum and astonished at the machines covered, especially my "new to me" INDEX 40 !
No motor but has power spindle feed; had power table feed in the past however, that's all gone but for the worm gear and inside of housing at the table end.
I had to disassemble it to get it to my trailer; swung by the car wash that had a hand-held wand; rattle-can of GUNK; gave it a long overdue bath !
Unload into the workshop and set to more cleaning, inspection, noting faults & needs.
Overall, in pretty good condition: lots of scraping still showing on the ways; eight(8) piece collet set; both Acme screws good but nuts, especially cross slide, pretty loose. Included was a ten page, type written listing of parts; unfortunately, for Serial Numbers 40-4124 & up.
The first signifcant repair item is going to be the intermediate, two(2) joined pulleys, jackshaft. Looks like a "field expedient" bespoke assembly that was less than accurate: allowed the upper #4014 and, lower #4013, pulleys to contact the #4016 base (I'm using part numbers off several images found herein).
OK... just like the game "rock, scissors, paper", I've got "rock 40-2215H"; used the "scissors" to get it home, and now need more informative "paper" !
It appears that the Manual that the Wells-Index folks sell, is the item I need to purchase ?
In the meantime, "more cleaning Drill Sargent !" as well as think about the 3/4 HP, 220/single phase, 5/8" shaft motor looking at me from the shelf.
My mother claims I started taking things apart and, putting them back together around age 5. Guessing that my father passed along his Tool & Die Maker genes also, 'cause it has gotten into much bigger things during the passing decades :)
Be a joy to hear from you all...
Don
Ulma Doctor
Infinitely Curious
Feb 2, 2013
837
congrats on the new to you mill!
there are lotsa folks who share your interests here.
i too played with my toys as a child for about 3 days before taking them apart to see what made them tick.
now i do it for a living :)
good luck and welcome aboard!
middle.road
Actively Learning...
Apr 28, 2014
2,582
Welcome, welcome.
Another Model 40 saved! very nice.
Chips'll Fly !
Feb 2, 2019
5
Thank You, fellas !
Talked with Audrey, nice gal, at Wells-Index yesterday; have a Model 40 Parts Manual heading my way !
Got to inspecting the first problem with my machine: the jackshaft, #1156, in the intermediate spindle drive pulley system. Quite the made-up jackshaft...
286954
Looks like a used piece of 3/4" fully slotted shafting was GTAW built up; turned to the bearings I.D.; necked-down and pressed into a hole drilled into the flanged, 7/8" stub ! Incidental, a "wedding band" was turned to space the two(2) #77504 bearings apart.
Both ends of the jackshaft are mushroomed/worn; I laughed at the marks left by the gripping jaws of a vice on the 7/8" stub :D. It'll go into my curio display case of rogue pieces I've overcome ! I think the #4013 and #4014 pulleys might be usable ? We'll see when I can confirm part numbers & availability !
Still giving the column and knee a good bathing; bead blasted the lead screw, knee lock, table lock, spindle lock crank handles; bit-o-wire wheel brush finish and they are beautiful !
Looking forward to the Parts Manual...
Don
jakes_66
H-M Supporter - Gold Member
Sep 21, 2017
81
Looks like that jackshaft was made on a tight budget... in a hurry... by an apprentice! :eek:
I've never used an Index Model 40. Got any photos? Welcome aboard, you'll find lots of good help and encouragement here.
Chips'll Fly !
Feb 2, 2019
5
Hiyah jakes_66... you should see the jackshaft in person !
Although, in my very early years, I made a few things that my Dad was kind enough to not laugh about (at least openly) !
Here's a picture of a Model 40 that mirrors mine, less all the tooling; I pulled it off the internet: credit eBay...
286969
As you read, mine is about fully disassembled and, in the I.R.A.N. (Inspect, Repair, As, Necessary) phase ! We're becoming very familiar with each other ;)
Don
jakes_66
Sep 21, 2017
81
Don,
Any progress on your Model 40? Haven't heard in a while, wanted to see if you had made any progress on the repairs?
-Jake
markba633csi
Apr 30, 2015
4,442
Hi Don, show us some pics of the Wells- did you decide to do a full teardown?
Mark
AdBlock Detected
I've Disabled AdBlock
