- Jan 1, 2014
- 233
Always wanted to do something about access to the two speed pulley on my 10" SB toolroom lathe, you sort of do it blind after you get you hands in there. Looked like it just needed a couple of hinges to swing the panel and a couple of threaded knobs to hold it closed. Only a small amount of metal needed to be removed for the hinges. Years ago I made an over centre mechanism to tighten/loosen the belt so having quick access to the belt just finished the job off. No cabinet strength is lost because it has a very solid welded frame.
Cheers
Cheers
