- Jun 8, 2016
- 603
I have a SB 16" that I need help hooking the motor back up. This is where it was when I bought it:
I had to move it so I disassembled it into major components. I screwed up, and simply cut the wires from the motor to the switches. It has what I call the 'overhead lever' switch which goes over the head stock. That is connected to two rocker type switches on the back of the machine:
There are 6 wires from the switches on back to the motor, which is 2 speed. The motor wires are marked T1, T2, T3, and T11, T12, T13. The wires from the switches to the motor are all black. I need to figure out which wires go to which.
Does anyone have a diagram, or is there a way to figure it out?
