SB 9 Headstock with Segmented Bearings
elecbob
Feb 2, 2011
25
Hello all,
I have a SB 9 headstock casting with spindle bearings that are segmented rather than smooth. The large bearing has 14 segments and the small (LH) bearing has 10 segments. It is a front oiler with bottom spring wicks and looks very similar to other 9 headstocks. The bearing cap bolts are not slotted or hex cap screws but are rounded hex head bolts. I think it is a later model due to the SB green paint. My 9" spindles fit nicely into the headstock. I think I saw this described as a "high-speed bearing" model.
Can anyone shed more light on this?
Bob
Mine has the same, made in 1945, SN 161674.... Hmmm, you sure about 2000 rpm Jim? Mine maxs out at 650 (8 spd, V-belts) but I guess I could change the motor pulley or use a 3450 motor. Sure would be handy to use faster speeds.
