- Jan 26, 2011
- 632
I need a dimension for the spring that goes against the brass shoe for the back gear shaft, since mine was missing when I got it. Everything is working on the lathe after the rebuilt, I just need that one part then I can try the back gear, which should be the last part I need for the lathe itself. I have been using it and adjusting things as I go along. I still have to do some work on the table like adding a shelf and made it a little less wobbly, but it is able to run like it is for now.
Thanks,
Paul
Thanks,
Paul
