I have some made from scrap QCTP holders. Two are from a 350 chevy crankshaft and an aluminum one cast from soda cans.
The knurling holder is probably 4 or 5 years old and like lots of projects for myself not quite finished. It gets to the usable stage and well.....I guess that's the important part.
It's from a main throw in the crankshaft, the hole is the hollow that is in the connecting rod journal. The knurling arms are from a road grader (some say patrol) blade (D2H steel).
The cut off holder is cast iron from the same crankshaft. Dovetail cut for the blade and has brass inserts under the blade hold down bolts.
The aluminum holder was cast from a tool holder as practice. To do a better job the tool holder used to cast from needs to be larger so there is material left for final machining.
A square bar was added on the bottom and I use it with a 90 deg piece of plastic to file checkering on the end of pieces in the lathe.
View attachment 281997View attachment 281998
