They can be added anywhere down stream of the pump, or off your existing tank. Doing this will Cause you compressor to run less often, but for a longer period of time. If you need more air (bead blaster, air sander,etc.) you would probably be better off upgrading to a higher output, two stage pump unit. Mike
